AdventureLab
- First Name
- Brit
- Joined
- Mar 14, 2025
- Threads
- 56
- Messages
- 930
- Reaction score
- 1,337
- Location
- St George, UT
- Vehicle(s)
- '24 RR
- Thread starter
- #1
Welcome
American Adventure Lab
www.AmericanAdventureLab.com
Phone: 385.202.4188 | Email: [email protected] | Instagram: @americanadventurelab
https://americanadventurelab.com/product/ford-ranger-a-pillar-ditch-light-brackets/
Additional lighting is one of the most useful upgrades for off-road travel, overlanding, and backcountry exploration. The challenge is finding a mounting solution that provides flexibility and strength without creating a bulky appearance or obstructing visibility.
We wanted a mounting system that was strong, modular, and low-profile while maintaining a clean factory-inspired look.
The American Adventure Lab Ford Ranger A-Pillar Light Brackets are designed specifically for 2024+ Ford Ranger and Ranger Raptor models. Constructed from 3/16" aluminum, these brackets provide a versatile platform for ditch lights, communication antennas, and future accessory configurations while maintaining a minimal appearance on the vehicle.
Features & Benefits:
• Designed specifically for 2024+ Ford Ranger and Ford Ranger Raptor models
• Constructed from 3/16" aluminum
• Rust-resistant aluminum construction
• Low-profile design intended to blend with the vehicle's appearance
• Designed to minimize impact on sight lines
• Interchangeable top plates support different lighting and communications configurations
• Optional antenna mounting configurations available
• Driver and Passenger Comms configurations support VHF/UHF antenna installations
• 10mm antenna mounting hole for compatible antenna systems
• Dual Pod Light configuration available
• Modular design allows for future accessory plate options
• Uses OEM hood mounting locations
• Textured black powder coat finish
Installation Notes:
• Uses OEM hood bolts for installation
• No additional mounting hardware required
• Top plate mounting bolts utilize M4 Allen head socket hardware
• Top plate mounting bolts are black zinc
• Available in Light Mounts Only, Driver Comms, Passenger Comms, and Dual Pod Light configurations
• Installation instructions available through the American Adventure Lab Instructions Library
Frequently Asked Questions
Will these fit my Ford Ranger?
These brackets are designed specifically for 2024+ Ford Ranger and Ford Ranger Raptor models.
Can I mount communication antennas?
Yes. The Driver Comms and Passenger Comms configurations are designed to accept VHF/UHF antennas using a 10mm mounting hole.
Can I run dual pod lights?
Yes. A Dual Pod Light configuration is available. Be sure to verify the mounting dimensions of your lights to ensure compatibility with your application.
What material are the brackets made from?
The brackets are constructed from 3/16" aluminum and are designed to resist rust.
Do I need to drill any holes to install them?
The brackets utilize the factory hood bolts for installation and do not require additional mounting hardware.
What finish are they available in?
The brackets are sold in a textured black powder coat finish.
Can I purchase them without antenna mounting provisions?
Yes. Customers who only need light mounting can select the "Light Mounts Only" configuration.
If you're looking for a clean, modular mounting solution for ditch lights, communication antennas, or future accessory expansion on your 2024+ Ford Ranger or Ranger Raptor, the American Adventure Lab A-Pillar Light Brackets provide a strong and adaptable platform designed to integrate seamlessly with your vehicle.
We're happy to answer any questions about fitment, lighting configurations, communications setups, or installation.
Installation Notes:
