IAG Off-Road
- Joined
- Aug 29, 2025
- Threads
- 10
- Messages
- 40
- Reaction score
- 109
- Location
- Westminster, MD
- Vehicle(s)
- 2024 Ranger Raptor
- Thread starter
- #1
Hey everyone,
We’ve been working on expanding our Ranger Raptor protection lineup, and our new Trail Shield® Complete Skid Plate System for the 2024+ Ranger Raptor is now available!
The goal was to provide more complete underbody coverage while keeping everything tucked up as tightly as possible. The system covers the front undercarriage, engine, transmission, transfer case, and fuel tank, with the individual plates designed to interlock and create a smooth, continuous surface underneath the truck.
The main plates are constructed from 1/4" 5052 aluminum, with steel reinforcement in key areas. We also incorporated a removable panel in the engine skid for easier oil changes, recessed mounting hardware to help prevent snagging on obstacles, and upgraded tubular steel fuel tank straps.
The complete system weighs approximately 125 lbs, sits about 1" to 1-3/4" lower than stock, and bolts to the factory mounting points without requiring any drilling. You can choose between raw aluminum and black powder coat finishes, and the system is proudly made here at our facility in Westminster, Maryland. It’s also backed by our limited lifetime warranty against structural failure.
Check out the new system here:
IAG Trail Shield® Complete Skid Plate Set
Here are a few photos showing the system, construction, and installed fitment:
We also put together an installation video if you want a closer look at how everything goes together:
This system builds on our existing Ranger Raptor protection lineup, which also includes lower trailing arm skid plates, rear shock skid plates, and our trailing arm sensor relocation. If you’re looking to protect those areas as well, you can find those products here:
IAG Trail Shield® Lower Trailing Arm Mount Skid Plate Set
IAG Trail Shield® Rear Shock Skid Plate Set
IAG Trail Shield® Lower Trailing Arm Sensor Relocation Kit
As always, if you have questions about fitment or installation, let us know. We’d love to hear what you think!
