AMPLIFIER - Kicker Key 200.4
jtvjr82
Joe
Poulsbo, Washington
2024 Ranger Lariat 2.7
There’s also an outfit out of Australia called Stealth Tech that makes unloaded sub enclosures for the passenger rear tub. Then you can load it with a 10” sub of your choosing. I just had one shipped to Tacoma, WA for just under $220 total and it arrived in about 12 days from Aus.
Plan on adding a Hertz 10” shallow mount sub which should be as good if not better than the JLA and I’ll be roughly $400-500 under the JL setup. This’ll get pushed by a still factory wrapped 2007 made in USA model Rockford Fosgate Punch 300.1 that I’ve been sitting on for nearly 20 years.
Just another thought.
Which hertz shallow mount are you going with?
Buellsox
Scott
Tacoma, WA
Local 26 Union Plumber
This is the setup I’m going with. It’s about a .1 cf off of being perfectly optimal, but I highly doubt I’ll be able to notice especially since I’m running a Borla ATAK exhaust system and it’s always in Sport or Baja and yes it’s loud. Plus it’ll be 100X better over that meager 5 1/4” sub in the B&O system. There’s an older thread of a Canadian member that runs this EXACT setup and he has nothing but high praise for the setup.
Based on their positive input of “it pounds” I’ve decided to go with the same setup and save some coin over the JLA which always seems to be on back order, but can be found on EBay, etc.
That’s the box I went with and got from Australia to WA State for about $220 total. Arrived in perfect shape.
Ford Ranger AMPLIFIER - Kicker Key 200.4 IMG_2271
Ford Ranger AMPLIFIER - Kicker Key 200.4 IMG_2273
Ford Ranger AMPLIFIER - Kicker Key 200.4 IMG_2227
