Any one drop the spare yet?
millertime496
james
northh of seattle
2024 ranger raptor
technical advisor
I should have known better than to not practice in my drive way BEFORE attempting to drive through a lava field, but is it just me or is the lowering bar not long enougn for the raptor, luckily I had a crescent wrench so I got it down, but that could have SUCKED.
And I eye balled it but it looks like you cant hang a flat if its on the factory wheel because the center cap is to small. The beds tiny ford, I dont have room to lug around a flat and all my gear.
Shadow Black Ranger Rapto
St. Louis, MO
I dropped mine to add an extension hose and the only issue I had was a slight offset when inserting the bar. No length issues. And have not attempted to carry factory wheel.
millertime496
millertime496
james
northh of seattle
2024 ranger raptor
technical advisor
Extension hose for the diff? I should probably do that while mine is down.
St. Louis, MO
14” extension hose for spare tire valve stem. So I can check pressure without dropping the spare. Needed to drop the spare to lower the pressure from 50 psi shipping pressure anyway.
millertime496
millertime496
james
northh of seattle
2024 ranger raptor
technical advisor
50, Well no wonder my alignment was off the whole drive home. I thought i knocked it out when i shredded the side wall.
jrRaptor
Maize, KS
No issues with mine. I swapped out the spare rim with a factory matched Raptor wheel.
