BCM Connector Pin Diagram Needed
JDough12
Rochester, NY
Hi all, just picked up my 2025 RR last week and starting to get some lighting on the truck!
Looking for a wiring diagram with the pinout for BCM plugs - looking for the location of the side marker light pin/wire
Trying to use the boostedgreygoose Raptor 3rd brake light harness I had on my f-150 for a 3rd brake light/chase light!
Thanks!!
john
Tucson, AZ
I wired my 3rd brake light chase lights to my Aux switch Go to your online owners manuel and go down to Aux Switches - Raptor It will show you where wiring is and colors and amps for each switch.
JDough12
Rochester, NY
yes definitely going to do that for the lights themselves
but want to wire my running lights/brake lights so they function like the big raptor
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
You only need to go at the bcm pons if your adding a cap for the 3rd brake, or a backrack with lights you want only brake.
otherwise ford provides 3 blunt cut wires you can use to trigger a relay for marker, and highbeam, and a ignition run trigger. all 3 of these are hooked to my diode dynamics dswitch.
The ford body builder layoutbook aka upfitter guide got some great info in it.
my 25 xlt the physical labels ford put on the wires, they had marker and high beam mixed up, but the uppfitter guide had it correct.
Under the BCM/Trailer module behind the kick panel
Ford Ranger BCM Connector Pin Diagram Needed Screenshot_20250621_084545_Adobe Acrobat
Ford Ranger BCM Connector Pin Diagram Needed Screenshot_20250621_073536_Adobe Acrobat
Ford Ranger BCM Connector Pin Diagram Needed 20250822_150423
Ford Ranger BCM Connector Pin Diagram Needed 20250822_150451
Ford Ranger BCM Connector Pin Diagram Needed 20260520_213144
Ford Ranger BCM Connector Pin Diagram Needed 20260520_182040
Ford Ranger BCM Connector Pin Diagram Needed 20250802_180922
Ford Ranger BCM Connector Pin Diagram Needed 20250802_180908
JDough12
Rochester, NY
oh awesome thank you so much!!
