Bill Hippel
Bill Hippel
Bill
Abington pa.
24 stx 4×4 Ranger
Retired carpenter
chasc
Illinois
2024 Ranger
I’m curious what you feel is the right inflation pressure for those. I have the same rim and tire takeoffs and tried calculating the correct PSI objectively but it ended up feeling too low while driving.
Bill Hippel
Bill Hippel
Bill
Abington pa.
24 stx 4×4 Ranger
Retired carpenter
Mavis tire inflated my tires to 35psi. It seems to be the correct psi. What psi are your tires?
chasc
Illinois
2024 Ranger
How was the tire shop involved? Had the seller dismounted the tires from the rims to remove the TPMS sensors?
In my research I found that the 5th gen Ranger Tremor (same tire) and Bronco Black Diamond both called for 39 psi on their door stickers. My 2024 Lariat with factory Goodyear Wranglers has 30 psi on the door sticker. I started with 35 and 37 psi but it didn't feel like it rolled as easily until I finally went to 39. Keep in mind the General Grabbers are C load range LT tires whereas the Wranglers are passenger tires, so that partly explains the higher pressures.
Bill Hippel
Bill Hippel
Bill
Abington pa.
24 stx 4×4 Ranger
Retired carpenter
No the tires, rims and TPMS were all together. Mavis removed the TPMS from my original rims and installed them in the Bronco rims. The General Grabber has a deeper and more aggressive tread. A higher psi would give a rougher ride , is my thought.
chasc
Illinois
2024 Ranger
So the takeoffs came with TPMS installed but you had the tire shop swap over the sensors from your original rims? Why? I just installed the takeoffs as they came and after a few miles the truck relearned all the new sensors.
Running at the recommended psi may be less comfortable but that’s part of the trade off of C load range vs P metric tires. Running under inflated can improve comfort but adds wear and tear.
Bill Hippel
Bill Hippel
Bill
Abington pa.
24 stx 4×4 Ranger
Retired carpenter
This is the way Mavis wanted to do it and i agree to it.
Bill Hippel
Bill Hippel
Bill
Abington pa.
24 stx 4×4 Ranger
Retired carpenter
35 to 37 is the recommended psi, so I'm ok with 35psi.
Rediviva
California
24' Ranger XL 4x4
I have the same tires (got Bronco steelie take offs), and I set to 35 also. Played around with the pressures, that seemed to be most comfortable.
I picked up four Bronco black diamond 265 70 17 tires and rims off marketplace for my stx Ranger. I was looking for the black on black look and I'm happy with the results.
Very sharp looking truck !
The Bronco wheels look great! 👍
jmt8706
2025 Ranger Lariat
I have those same General Grabbers on my work truck, they will likely be what I put on the ranger next. Great winter performance.
