Cabin Vibrations at highway speeds (70 mph+)
az ranger
peter
arizona
2025 ford ranger lariat
***Resolved. Thank you all for your responses on what the culprit may be. I was suspicious of the wheels being the issue, after removal, I measured them at the toyota hub bore of 95.1 mm, and couldn't find any hub ring, or even if it was possible to get a 2 mm hub centric ring made, so I found a set of bronco wildtrack take offs (+30 from google search, tires are falken at4 275/70/17) and they did the trick. Rides like a completely different truck. Thank you all again and appreciate this community!
Ford Ranger Cabin Vibrations at highway speeds (70 mph+) IMG_4904
Ford Ranger Cabin Vibrations at highway speeds (70 mph+) IMG_4897
Ford Ranger Cabin Vibrations at highway speeds (70 mph+) IMG_4901
OxygenMask
Phil
Eugene, Oregon
I've bought hub rings as small .8 mm...
My Magnum wagon needed just 1mm rings to get the aftermarket wheels to run true...
