Charging system fault
Skully
Craig
San Antonio TX
2024 Ranger
Sales
I'm 8 days into my new Ranger and am getting charging system faults. They come and go and the center screen has shut off twice and come back on. Dealer cant look at it until Monday so this is fun start.
joprato
Jonathan
bahrain
ranger raptor next gen
pilot
I’ve seen this with loose battery terminals before… could it be that ?
HT00124
Sean
Nova Scotia, Canada
2024 Ford Ranger XLT
Snr. Hull Technologist
My 2024 Ranger Sport XLT is in the shop agin for the second time with this fault. Last time all they did was clear a code for low battery voltage and load tested the battery, took it out for a road test and couldn’t find any faults. Said everything was fine, next day the fault came in again 5 times with in 20 minutes. Took it back to the Dealership and tore a strip off the Service Manager and lo and behold their Field Engineer found 3 failures somewhere in the system. Hopefully have it back this week with an explanation as to what happened. This all started with about 2000kms. Shouldn’t be happening with a weeks old vehicle.
Sam55
Tennessee
2024 Ranger
I was told by my Ford dealer that the SYNC 4 software is a problem and allegedly Ford is working on a fix but no date was given as to when. Lots of issues with the SYNC4 software. My 2024 has had several issues.
Hootbro
Delaware
2024 Ranger STX 4X4
You saying the SYNC 4 software is causing a charging fault or is this a different unrelated issue?
Sam55
Tennessee
2024 Ranger
Not really sure but when I tool mine in for several issues, that is what the ford dealer told me. I was told to be patient as they were working on a fix.
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Ford Ranger
Good morning! If you'd like to, go ahead and send us a private message with your VIN and dealer info and we’ll look into this charge fault concern. Thanks!
Skully
Skully
Craig
San Antonio TX
2024 Ranger
Sales
Thanks, I sent the information you requested. The truck wouldn't start Saturday night and is at the dealer now.
pablo94sc
Focus
Update on this. A ground was improperly installed at the factory. Back up and running now.
Glad to hear that. It sounded like a ground issue. Those can be a real PITA to troubleshoot at home. Imagine trying to diagnose a hot start issue and checking the engine ground.
Pro tip: welders gloves do a good job of keeping your skin from searing to the manifold.
Boomerrang
Dufur, Oregon
2025 XLT Ranger, 2019 F150
Semi-Retired auto tech
Where was the bad ground. My 2025 is having a problem not charging at times.
Thanks Dave
Boomerrang
Dufur, Oregon
Found the loose bolt on the ground strap. Engine ground strap is in front of the engine under the skid plate. Sure this will fix my problem also.
