Cold Air Intake Worth It? 2.3L I4 Turbo
blm28164
Brandon
Beulaville NC
2024 Ford Ranger XLT Supercrew
PMQC Inspector
Hello everyone, I am new here. I just bought a 2024 XLT Supercrew with the 2.3L I4 Turbo. I was just researching some stuff and came across this cold air intake. Do you think it would be worth the money? I know it says not released yet but I’m curious on opinions.
https://a.co/d/4LXdVy7
Ford Ranger Cold Air Intake Worth It?  2.3L I4 Turbo IMG_9252
to me, not worth 450 bucks when your factory intake is already a cold air intake.
Sauce
Northeast
2025 Ranger XLT FX4
Im in the same boat. Probably going to go for the Procal first.
Only reason I was even considering the intake is that it does improve the sound of the vehicle. Yes the stock intake is cold air, but some of these aftermarket intakes should offer more flow and maybe better flowing filters (which may come at the expense of actual filtering). If I did an intake I’d go with the k&n or AFE with dry filter which is slightly more restrictive but lower maintenance and better filtration. The reality is that performance improvement with these is marginal, if anything but they do sound good. The performance improvement should be definitely be more meaningful on the procal if that’s what you’re after.
blm28164
blm28164
Brandon
Beulaville NC
PMQC Inspector
Oh ok! Is the Procal like a chip tuning thing? I did see where you could get a tuning for like $800-$900 to where it gives more horsepower and torque but then you have to use 91 octane gas or above.
Sauce
Northeast
2025 Ranger XLT FX4
Yea. That’s the one. Ford Performance tune. And yes, the higher grade gas is a downside.
blm28164
blm28164
Brandon
Beulaville NC
PMQC Inspector
If you do the Procal, let me know how you like it.
i have it on my 2.3. you can definitely feel a difference and it makes the trans shifting better, too
blm28164
blm28164
Brandon
Beulaville NC
PMQC Inspector
That’s cool! Is it a drastic difference in the 0-60 acceleration? Also, does it affect towing capacity as well with the extra power?
gaiello1972
Giuseppe
2024 Ford Ranger XLT FX4
Im hoping to get that shipped to me, but the reason is for more air flow into the motor, the stock tubing and filter has a smaller CFM, i did it on previous trucks and the air flow is much greater with a newer intake filter.
blm28164
blm28164
Brandon
Beulaville NC
PMQC Inspector
That’s cool! Would there be any noticeable difference in power vs the stock cold air intake?
gaiello1972
Giuseppe
There will be a difference especially in fuel economy and some throttle response because there the motor is not struggling for air. However, the PCM isnt just gonna change right away its gonna learn that is is getting more airflow at the change of the throttle position.
not all motors are the same so just because it worked on another motor, doesn't mean that will have the same effect here. you need to see what the cfm of the system is, or if it meets or exceeds the requirements of the motor. some motors have an intake system that already lets in more than enough air and that means the intake is not the restriction to power.
i am not sure how much of a difference it makes on 0-60 because i didn't really check it like i did afterwards because i was comparing my wife's 2.0 turbo wrangler to my truck so i did actual 0-60 runs using an app to test 0-60 times. it doesn't lower your towing capacity, having the tune. whether it tows easier or not, i am not sure. i hardly ever tow and ahve not with this truck, yet
NW 150
Nick
New Franklin
2024 Ford Ranger FX4
For $100 cheaper you'll be able to get one from S&B in the next month or so.
JR RANGER
JR
Auburn CA
2024 Ranger XLT FX4 4x4
How did it effect your gas mileage.
JRRanger
