Dash Lit Up Like a Christmas Tree
pitcritter
Saskatchewan
2026 Ranger Lariatp
I'm hoping that someone here can share some insight into what might be going on with my '26 Lariat 2.7.
I bought it new in September and at the end of October I drove it from Central Saskatchewan to Puerto Penasco Mexico. We're here for the winter.
It has been flawless. I did an early oil change before the road trip and everything worked perfectly on the way down.
Two days after we arrived, while driving in normal city traffic, my dashboard indicators blew up.
I got all of the following indicators coming in sequentially:
Park brake limited function service required
Hill Start Assist not available
Memory recall not permitted while driving
Service AdvanceTrac
Pre-collision assist not available
Parking sensors fault
Blind spot system fault
Cross traffic system fault
All of these disappear with the OK button but the"Memory recall not permitted while driving" comes back.
Everything else seems to be working normally, although I have no cruise control.
I'm four hours away from the closest Ford dealer in Phoenix and that requires 90 minutes on an under-construction cart path to get back to the US border. I'd rather avoid it if possible.
On the drive down, I drove through torrential rain in Phoenix. I'm guessing that water may have gotten into the door and messed something up. That was almost two weeks ago. We haven't had a drop of rain since. It should have dried out by now if that was the problem.
I'm led to this conclusion due to the memory recall buttons being located high in the door.
I've tried disconnecting the battery for a couple of hours. That did nothing.
I bought a cheap OBD2 reader and that showed no codes.
I made a weak attempt to pry out the memory button module on the door to take a look but I don't want to risk damaging my door panel and I have limited tools with me.
I wonder if my next step would be to order a Forscan compatible reader and give that a try. I have a little Forscan experience from previous F150s.
Any suggestions?
bgn
Seattle
2022 Maverick Lariat FX4
This looks like some type of harness issue or maybe a module gone haywire. I would not attempt to fix it yourself. I especially would not assume that the memory seat buttons can be popped out without taking the door card off. And again, I wouldn't even assume that's the issue.
You may be able to find a Ford dealer in Mexico to help you. The warranty should be for all of North America. But of course call them and check.
LittleRed
Brent
Grand Junction Co
2026 Ranger Lariat FX4
OTR Driver
Simple fix would be to disconnect the battery for 10 minutes or more & see if that resets stuff. Also check your radar sensors for dirt or debris
Mystic
Rusty
SoCal
'24 RR, '25 Explorer ST
Estimator
How much do you trust the gas down there? 🤔
pitcritter
Saskatchewan
2026 Ranger Lariatp
I've already disconnected the battery for a couple of hours...nothing.
The sensors are fine.
The gas was from BucEes outside of Phoenix. I didn't gas up here until afterwards.
It might be time too bite the bullet and make the trek back to phx.
emjay24l
SW-VA
2024 Ranger Lariat FX-4
Civil Engineer
You might be in Phoenix for a while. I took my Ranger to the dealer a week and a half ago and they just looked at it yesterday. My problem was what appears to be brake fluid leaking near the front right wheel and not something complicated like you are experiencing. Ford dealerships are losing mechanics at a fast pace because they are not paying them book rates for warranty repairs. So when warranty work comes in they pass on doing it if non warranty work is available. At least in Phoenix there should be a lot of Ford dealers to pick from.
pitcritter
Saskatchewan
2026 Ranger Lariatp
Thanks for that info. That really makes for a tough decision. It's already 4 hours one way over terrible roads. They also advise not driving that route in the dark. I won't leave my wife in Mexico by herself for more than a day. Even a loaner won't help since you're only allowed into Mexico on a personally owned vehicle with valid Mexican insurance.
I think I'll monitor it and see if it gets any worse. Right now it's still perfectly driveable .
If I happen to be in PHX or Yuma I'll see if I can get in to have it diagnosed.
TurboRanger
Jack
Oakley , Comifornia
Retired Truck Mechanic
We had a work truck do this 22 F 350 took it to the dealer and they could not find out why They thing a mouse chewed in wires someplace by the ECU . I would look for mouse foot prints under the hood Right now before it gets cold they get busy looking for a warm place
pbouy
Paul
Plaquemine, LA
2025 Ranger XLT
My 2025 with 2.3 eng has done this twice. I haven't been off-road or driven through flooded roads. I bought it in December 2025 with 1006 miles on it. It's only at 6312 miles now, so it doesn't get used very much.
After parking it overnight, everything reset and worked fine for a couple of months. So far, only did it twice. We have no Ford dealer here, so I'll monitor it too.
pitcritter
Saskatchewan
2026 Ranger Lariatp
Here's a strange wrap-up (I hope) to a strange problem... The truck stayed exactly the same since I first posted. No change at all until today when I needed to go to the store. I didn't even notice at first but everything is back to normal. No idiot lights on the dash. No annoying chimes. Adaptive cruise works perfectly.
I'm assuming it was moisture.
Time will tell if it comes back.
LittleRed
Brent
Grand Junction Co
OTR Driver
Did you happen to check the battery voltage?
a week battery can cause weird things
