DRL with turn signal
RedTurboMr2
2026 Ford Ranger Raptor
I noticed in the forscan spreadsheet that you can enable the DRLs to flash with the turn signals. I just tried it and it doesn't work. I'm not sure if it's because i'm using the signature lux boards. Has any got it to work?
smokinjoe64
SoCal
Hmmm curious... intent/attempt for DRLs to 'blink' together with turn signal activated or something else?
RedTurboMr2
RedTurboMr2
Right now the drl dims when I use the turn signal. Apparently there's a way to have the drl not dim and blink with the turn signal. Might not work with the signature Lux boards. Just wondering if i'm missing a step on forscan. I changed the code in the BCM as built menu and also tried a couple settings in the non as-built, but it wouldn't work.
Ereo
2019 Ford Ranger XLT
i know on the 5g ranger, you need to do a unique combo to make the DRLs use the turn signals and still have the turn signals work. could be a similar method but since I dont currently own a 6g i cannot give much further guidance
RedTurboMr2
RedTurboMr2
Yeah, there's probably a few things that need to be done. I tried a cpl combos. I'm wondering if it might be because the Signature Lux boards or i'm missing a step. I don't care too much for it to blink, but i'd rather it blink than to dim.
smokinjoe64
SoCal
@RedTurboMr2 consider an approach found successful with Forscan coding.
For instance, specifically setting DRL 'fixed' brightness level, combining fogs w/DRL function, 'bambi' mode among other coding modifications.
Reposted comments...have a look
RedTurboMr2
RedTurboMr2
Hmm, I wonder what the DRL menu is. It doesn't mention using DRL with turn signal. I have most of the other stuff enabled including Bambi mode.
FergyA
LA County, CA
'24 Ranger XLT FX4
Mech. Engineer
The default is to turn the DRL off on the side the turn signal is on, making the truck "wink". The forscan setting just overrides that to make the DRL either dim slightly or stay full bright. It does not/cannot make the DRL blink as far as I know.
RedTurboMr2
RedTurboMr2
I couldn't get it to stay full bright, it would dim everytime. It dims even with the stock settings, it doesn't turn off.
