For those that have done the Forscan VDM suspension height adaptation (RR)
ag02m5
Google
Did the front level kit and then did the Forscan VDM adaptation myself after.
I followed the instructions for the Ranger Raptor, putting it in Engineering Test (ET) mode first.
Initially the values were what I'd expect after the lift but after several tries with Forscan, I cannot get the values to 0. They all stay at 2.
Thoughts?
Thanks.
Ford Ranger For those that have done the Forscan VDM suspension height adaptation (RR) forscan
Klutch
Cole
Saskatchewan
IIRC i had the same outcome. Not a zero reading. The 2.0mm does ring a bell. I'll try and check when i get a chance.
Klutch
Cole
Saskatchewan
Mine fluctuate between 0 and - 0.04" which would be a -1mm after calibration.
ag02m5
ag02m5
Google
Thanks. Mine sits solid at 2mm.
Klutch
Cole
Saskatchewan
While we're at it does anybody know how to do the part circled in red here?
Ford Ranger For those that have done the Forscan VDM suspension height adaptation (RR) 20250303_185401
ag02m5
ag02m5
Google
Ha. I didn't even catch that part! I was focused on the lower section which took some research.
I did mine after it had sat overnight. Not sure if that is better or worse for temperature calibration.
ag02m5
ag02m5
Google
Side note that my headlights were way out after. I had to manually adjust them down.
OffRoad_Rec
Enzo
Mass
Thoughts?
Thanks.
Here is the link to help you. For what ever reason you need to unplug the sensor and then recalibrate it. I did this on my bronco and got zero after calibration.
Klutch
Cole
Saskatchewan
I beleive that was just so he could get the vdm to show up in the menu? VDM was already in my menu without unplugging a shock.
OffRoad_Rec
Enzo
Mass
It makes the calibration for it pop up under VDM. I’m going to add a lift and change my tires this summer on my RR I will try making a video of the process to calibrate the height.
Peter949
Peter
Irvine, CA
Just did the process to soften my Eibach leveling springs lift. I think it's a little softer ride now. Need more driving to assess.
