HyperM3
Lawrenceville, NJ
Thanks. I'll add this to the sheet when I get a moment. BTW, the menu option (i.e. non as-built) for this is "Using DRL with Turn Signal"
I took it from the sheet!
DesertSand
Alberta
Null
Just curious if anyone has looked at the trailer brake settings for the xl Ranger and if it can be "turned on"? Thanks.
RangerDangerStranger
SF Bay Area
2024 XLT 4x4 in GreyBlue.
Cool Dude
there's no module installed for it, so you can turn it on, but it's not gonna do you any good. If you have the basic tow package, there's a connector to the left of the brake pedal that you can plug-in, to any of the current bronco trailer brake controllers. Plug and play you don't have to turn anything on. If you don't have that, that's a more difficult animal to tackle. I don't believe the connectors there on non-basic tow package trucks. XL, XLT or even Lariot it doesn't matter. Basic package feeds, the seven pin connector. With everything but the trail bake signal. Get that you need the controller. This is True for 2024 Rangers, it looks like they're installing a TBC on the basic package for the 2025s, though I haven't looked into that as much
DesertSand
Alberta
Null
I have the tow package on my 2025 I ordered. So all I need is the brake control from the Bronco or could I install the factory one in the factory location? Thanks!
craigc
craigc
Craig
Allen, TX
it was not in the Features-confirmed tab. Once a feature is confirmed I move it from the Features-TBD to Features-confirmed.... Maybe overkill, but there was so much junk copied from F150 that we don't know if work or not, I kept the tabs seperate... Anyway, thanks for keeping this going!
craigc
craigc
Craig
Allen, TX
He was saying that it looks like 2025 includes the TBC but not the 2024 (anger face), so if that's the case since you have 2025 with basic tow you should be fine without adding anything. for my 2024, I have not yet tried the bronco fix as I'm still not clear of how the physical squeeze button gets added as there is no wiring for that (to the right of the steering column). I was hoping by now Ford would release something specific on the accesories page but that seems like it'll never happen.
DesertSand
Alberta
Null
That's crappy for the 2024 owners. I hope it will be easy install and solutions for you.
SF Bay Area
Cool Dude
I believe the 2025s might be coming with a TBC already installed. If not, then all you would need would be one from the current bronco. RedARC would work. They're plug and play to that connector. and the connector has the right signals to make it work. And an output to the control wire in the seven pin.
RR24
yaser
dubai
ranger raptor 2024
i would like to know if its possible to reset the transmission or clearing the Transmission Adaptive Table using Forscan. Resetting its learning operation, RR 24 as i have jurk from 4th to 3rd and 5th to 6th despite the harsh shifting.
HyperM3
Lawrenceville, NJ
Ahh I got you. I thought I confirmed it back in the day when we were putting the sheet together. My apologies.
DesertSand
Alberta
Null
Someone is getting their transmission replaced because of issue similar to what you are describing. You may wanna book an appointment with Ford.
Sequoia
Dan
Germany
Ranger Wildtrak 2023
Hello everyone,
I need your help regarding tire sizes. I switched from 255/65/R18 to 265/60/R18, and now my speedometer is off by about 10%. So, I looked into how to adjust it and came across this video, which turned out to be super helpful. It worked perfectly.
My original value was 2406mm, and I changed it to 2300mm. After that, my speedometer was spot on! I drove the car, came back home, reconnected the system, and then got the TCM DTC P160A error. I can’t get rid of it. Even resetting and reprogramming the TCM, as shown in the video, didn’t help.
Now, I’m stuck and don’t know what to do to finally fix my speedometer. I even left a comment on the video, and the creator offered to help.
Any ideas?
MAV
Arkansas
You have to do a PCM relearn process also. The P160A error indicates mismatch between the PCM and the BCM.
Sequoia
Dan
Germany
I did all this like it is described in the video.
Set value
PCM relearn
TCM relearn
AWD relearn
Clear all DTC.
All DTCs gone except TCM P160A
Sequoia
Dan
Germany
Next question: The Bronco has a tire camera. A friend of mine suddenly had the icon appear on his Wildtrak after making some changes in FORScan (he doesn’t remember exactly what he changed). However, when he presses the button, nothing happens. Does anyone know how to activate the camera (it’s taken from the ultra-wide-angle lenses on the mirrors)?
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_3D2F9F76D62A-1
