Front 2 inch receiver
soulwriter
Allen
South Carolina
2025 Ford Ranger XLT and 2025 Ford Explorer ST
Business Owner
I haven't seen anywhere that there's a solution to the front hitch for gen 6. If anyone knows anything different, please check in. Thank you!
Pic-N-Stick
Northern Virginia, USA
Retired Firefighter
Best solution for me was a swing-away hitch on the rear. At least it allows me to access the bed contents without removing the cooler/rod rack.
Ford Ranger Front 2 inch receiver 1778371425669-c
Ford Ranger Front 2 inch receiver 1778371481338-8d
Ford Ranger Front 2 inch receiver 1778371617743-t8
soulwriter
Allen
South Carolina
Business Owner
You are right, for some reason the '24 isn't flat towable.
But in all cases, only 4x4s are flat towable because it's the transfer case that's being put into neutral.
Manual says:
Recreationally Towing Your Vehicle - 4x2
You cannot recreational tow your vehicle with all wheels on the ground because vehicle or transmission damage could occur. You must recreational tow your vehicle with all four wheels off the ground, such as when using a car-hauling trailer. Otherwise, you cannot recreational tow your vehicle.
I'm still trying to find some solution for the front hitch because I want to get a winch but I'm going to have to use it on the front and back.
