how does the remote start make heater warm up quick??
porgey
George
Bloomington Il
2024 Ford Ranger XL Blue
HD truck mechanic
using remote start the cab heat is there quick!! If ya go out start with key leave sit a bit not much cab heat...seems to be a electric heater grid in air box somewhere??? Yes..No??? thinking ac comes on auto with remote start also
RangerDangerStranger
SF Bay Area
2024 XLT 4x4 in GreyBlue.
Cool Dude
No. there's no engineered magic. It will slam everything into full hot though. I seem to remember somewhere in the menus there is a temp function on/off for remote start.
Trimjb
Tennessee
2024 Ranger FX4
Maybe I'm wrong but I was under the assumption it will use the last setting when you shut it down last.
I only tested remote start once. My truck is garaged.
I don't have the Ford pass controls on mine to fine tune it.
BuenaRaptor
Erik
Vail, Colorado
2024Ranger Raptor
Estate Management
If you go thru the app and ‘slide to start‘ you can adjust the temp, seat heat, steering wheel heat and defrost. Awesome!
natethegreat42
Nate
Minnesota
Ford Taurus
When you remote start with your key, it will default to the setting in the truck depending on the exterior temperature. In the winter, if you have heated seats (and steering wheel I presume) it will also turn the drivers side on.
Same thing used to go for the FordPass app until very recently when a feature has begun rolling out to folks that allows them to set the temp, defroster and drivers side seat heater manually when you “Slide to start”.
The only time it will start to the last climate settings before you turned the truck off is when you “schedule” a remote start in the FordPass app. Which is why I have never used that feature.
RANGER PRIDE
Niagara Ontario
2024 Ranger Supercrew Sport
I asked AI if the ranger had a supplemental heat system. I had heard before we did.
Didnt know how it functioned, but now I do.
Ford Ranger how does the remote start   make heater warm up quick?? 1766705782258-gi
jmt8706
2025 Ranger Lariat
I always wondered why gassers don't get that supplemental cabin heater that the diesels do.
jedadiah
Jed
Kentucky
I had a VW TDI and if it weren't for the supplemental heater, idling would have taken a very long time to warm it up. The heater was needed because even when driving it would take longer than one would like.
