Just ordered a set of RTR EVO 6 wheels!
Daweism
Austin, TX
Ordered a set of 5 RTR EVO 6 17x9 30mm in satin black. Nice 15% off coupon right now.
Ford Ranger Just ordered a set of RTR EVO 6 wheels! 1739161117784-yc
I don't even have a Ranger Raptor yet lol.
Waiting on my 2025 Velocity Blue order ?
YeahNahRaptor
Drew
Might wanna check the lug size. I just put on some aftermarket’s and I needed 14x 1.5. Not 12
Daweism
Daweism
Austin, TX
What was your offset? These are the only lugs RTR offers on their site for the Ranger.
YeahNahRaptor
Drew
Zero offset. I spoke with the wheel manufacturer who also said at the start 12x1.5 but after some back and forth and digging online we found that it was actually 14x1.5. Installed last week
Catalyst
Justin
Bend, OR USA
Network Engineer
You must have a strange '24 Ranger if you're using that lug size vs. M12x1.5.
Daweism
Daweism
Austin, TX
What size lugs do you use on your aftermarket wheel?
Catalyst
Justin
Bend, OR USA
Network Engineer
Regardless of OEM or aftermarket wheels - the thread pitch stays the same. You will need a 60* taper (acorn bulge typically for trucks) seat for most aftermarket wheels. The lugs from RTR will work fine, but unless you got some bastard Ranger, the thread pitch will be M12x1.5.
YeahNahRaptor
Drew
??‍♂ that’s what the tire used and put on there. Had a back up set of M12 x 1.5 and they went with the 14
YeahNahRaptor
Drew
Guys I am so sorry!! Ugh I was wrong. My bad. They are M12 x 1.5. Idk why I thought they were 14 and the wheel dealer told me that. Apologies for wasting everyone’s time!
Daweism
Daweism
Austin, TX
Yeah would've been odd if the only lugs RTR sold didn't go on the wheels RTR specifically manufactured for the Ranger/Bronco.
harper7
Claremore Oklahoma
2024 Ranger Raptor- Velocity Blue
Mechanic
Those are pretty nice and the +30 offset should be perfect as that will push the wheel 1 inch outward from stock!
The charcoal gray to match the fender flares I like is out of stock though in the EVO 6 but have it in stock for the TECH 6.
I couldn't find the weights listed so I asked them and waiting for reply.
Where did you get the 15% off ?
Daweism
Daweism
Austin, TX
The 15% code is just WELCOME15.
The charcoal gray satin DOES NOT match the fenders so beware. They are much lighter and a primer looking color in person.
Ford Ranger Just ordered a set of RTR EVO 6 wheels! rtr-evo-6-bronco-wheel-charcoal-lifestyle-0010__59018
harper7
Claremore Oklahoma
Mechanic
Thanks ... After some research on youtube that gray is too light of a color and definitely not Charcoal like the name. Weird they would call it that when it should be called as you stated "primer gray"
RTR did get back to me on the weights yesterday. I read on reviews that they were 21 lbs which would be a big selling point and ........ no. Still less the stock non beadlock wheels.
From RTR
Please see wheel weights below:
RTR Evo 6 Wheels in 17x9 are 24.5lbs. per wheel.
RTR Tech 6 Wheels in 17x9 are 27.5lbs. per wheel.
I'm probably going to get the Method 703 or 705 beadlocks when I upgrade . I had the 703's on a previous 4Runner . Super strong offroad and easy to clean! Their gray is darker too and more like gunmetal and about the same weight.
Daweism
Daweism
Austin, TX
From RTR
Another selling point of the RTR are the 9inch width which widens out the contact area of the tire tread a little. Not sure if it's enough to notice a difference but it is what it is. I've read everywhere the 17x9 RTR EVO 6 are 22lbs, even said by the RTR rep on the Bronco6G forums. Not sure why they told you 24.5 or if they changed recently. They might have given you the weight of the F150 Raptor / Bronco Raptor version of the wheel.
https://www.bronco6g.com/forum/threads/rtr-evo-6-wheels.55249/
Ford Ranger Just ordered a set of RTR EVO 6 wheels! 1739301644866-6m
