Lower control arm torque spec?
JrHDRanger
Indiana
Does anyone know or have access to a shop manual that can share what the torque spec is for the lower control arm pivot bolt? This is for a 2025 Ranger Raptor. I believe the bushing has some bind in it after my lift (the upper one did, but I found the specs for that one)and want to loosen and retorque to spec before I get an alignment next week.
brianh87
Pittsburgh
2026 Ranger Raptor / 2021 Explorer ST
The lower control arm ball joint nut is 85 ft/lbs
The lower arm bolts with the cam washers are 210 ft/lbs
The strut bolt to the lower arm is 406 ft/lbs
DM me if you want the official lower arm installation / removal procedure.
JrHDRanger
JrHDRanger
Indiana
Thanks! The 210 spec was what I needed.
