Sauce
Northeast
2025 Ranger XLT FX4
Finally got my aux fog lights installed. Tried a bunch of different brackets before I found something that worked well. They seem very solid. Need to add some washers but otherwise good to go.
only modifications needed on the bracket were drilling the holes larger. Also had to grind down the morimoto bolt to make it fit.
morimoto 2 banger wide beam
<<Deleted original bracket link because they rusted. See below for a link to a better replacement>>
Ford Ranger Lower valance aux fog lights installed on 2025 Ranger XLT IMG_1822
Ford Ranger Lower valance aux fog lights installed on 2025 Ranger XLT IMG_1824
Ford Ranger Lower valance aux fog lights installed on 2025 Ranger XLT IMG_1820
TexasCajun
TexasCajun
2019-2025 Ranger
What did you use for the Hood light brackets? I have some Ford Motorsport Rigdit light I want to mount.
Reactions: Doc
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
Reactions: Doc
TexasCajun
TexasCajun
2019-2025 Ranger
The A pillars would be the ones. I've been looking for brackets so thank you for the link, I'll be getting them.
Reactions: Doc
el_sabio
Randall
Tennessee
24 Ranger XLT FX4
here’s the bracket (I pray they don’t rust)
Mewutal 10pcs Z Brackets 1-3/4"... https://www.amazon.com/dp/B0DV36ZS28?ref=ppx_pop_mob_ap_share
No interference with the Adaptive Cruise radar? I like this setup, smart!
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
No issues at all. I’m going to swap the brackets out for something more corrosion resistant eventually but otherwise they work perfectly.
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
The original brackets corroded almost immediately (as I suspected). I have now replaced with these which are Stainless. Had to shorten them with a saw and dremel but no issue and the dimensions are otherwise perfect.
https://a.co/d/aeWjSKv
ryanO
Ryan
2025 RangerXLT
Sales
Awesome! Have you installed upfitter switches? If so, which did you go with?
ryanO
Ryan
2025 RangerXLT
Sales
They look great! What upfitter switch solution did you go with?
