Need help. Broken fuel line.
Mike47
Carrollton, GA
2024 Ranger
Engineer Technician.
Hey yall, I was driving my 2024 ranger 4x4 2.3 down an old logging road yesterday when a stick somehow stood up and broke a fuel line off flush at a quick disconnect coupling between the fuel tank and the frame. I think its the feed line from the tank heading to the engine. Anyway i was a mile down a logging “trail” on Sunday afternoon so i cut out the quick disconnect and coupled the line back together with a 3” rubber fuel hose which got me home.
I am trying to find the part numbers for replacement lines but i cant find any fuel line diagrams online. I would like to order the parts and install myself. Im trying to avoid driving to the dealer. Does anyone know where i can find a fuel line diagram with part numbers? Any help would be appreciated.
Thanks
Mike D.
ChronciallyChronic
Central Florida
2024 Ford Ranger Lariat
Thanks
Mike D.
I think a good way to get what your needing is take some pictures of the line and the area it's in then get with the parts department of your dealer. They should be able to determine what you're needing pretty quickly and get it on order if it's not something they keep in stock.
Switzguy
Minnesota
2025 Ranger Raptor, 2018 BMW M240i
Ran your post through google's AI thing and here's what it came back with.
For a
2024 Ford Ranger 4x4 with the 2.3L EcoBoost
, Ford generally does not sell the quick disconnect couplings as standalone parts; they are integrated into the full fuel tube assemblies. Since you are trying to replace the feed line between the tank and the frame, you are likely looking for the Fuel Feed Tube Assembly.
Potential Part Numbers
Based on current diagrams for the 2024 Ranger 2.3L, here are the likely components you'll need:
  • Fuel Feed Tube (Tank to Engine Area): Often listed under base part number 9G291. A specific front fuel tube for some 2024 configurations is
    JL3Z-9G291-A
    , though you should verify this against your specific VIN to ensure it matches the 4x4 chassis length.
  • Fuel Filler Hose: If the damage was nearer to the fill point, the part is
    MB3Z-9047-N
  • Fuel Tank Sender/Pump Assembly: If the break happened right at the tank's output nipple, the full assembly is
    KB3Z-9A299-C
    Ourisman Ford of Manassas +3
Where to Find Diagrams
You can view exploded parts diagrams and verify the exact fit for your VIN at these official and authorized catalogs:
  • Ford Parts Catalog: Enter your VIN to see the exact "Fuel System" diagrams for your specific build.
  • FordPartsGiant: Provides detailed exploded views and supersession data for 2024 models.
  • Lakeland Ford Parts: Offers a broken-down list of fuel system components specifically for the 2.3L 4WD.
    Lakeland Ford Online Parts +2
DIY Repair Note
If you prefer not to replace the entire long run of hard line, retailers like Advance Auto Parts and AutoZone sell Dorman Quick Disconnect repair kits (e.g.,
Dorman 800-050
). These allow you to splice a new nylon line and connector onto your existing line using a union, which might be easier than routing a whole new assembly over the frame.
Advance Auto Parts +2
Mike47
Carrollton, GA
2024 Ranger
For a
    JL3Z-9G291-A
    MB3Z-9047-N
    KB3Z-9A299-C
DIY Repair Note
Dorman 800-050
Thank you very much for the information. I do intend to replace the whole line.
Mike D.
At least you can use it still with the temp repair
