HGHVLTS’ 2025 Raptor build “ish”
STEVE_K
Snohomish, WA
The new wheels look great! Did you paint the brake calipers or did they come in black?
HGHVLTS
HGHVLTS
24 Integra Type S, 65 Mustang Fastback, 71 Skyline 2000GT, 72 Celica ST
Electric System Operator
Thanks, It’s just the lighting, the calipers aren’t painted.
corysquires
Cory
AZ
IT
Congratulations on the new ride. Beautiful
yoopercharged
Wheels look great! Love the bronze rings.
HGHVLTS
HGHVLTS
Thanks, I think they turned out awesome, loving the new offset also. Was debating to do the rim itself in bronze and a black ring, but wanted a contrast between ring and tire. Also kinda dumb, but I'm going for a white and bronze theme along with my Integra Type S.
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_1720
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_0522
HGHVLTS
HGHVLTS
Arrived today, Got the Ford Performance Air/oil separators installed. As stated in other posts, the drivers side bracket will be bent ever so slightly to make sure it doesn’t make contact with the A/C lines.
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_1748
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_1749
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_1754
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_1755
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_1756
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_1757
HGHVLTS
HGHVLTS
Finally got the black lug nuts, black locks, and bronze valve caps on. Accidentally order the wrong ones before or they would have been black from the start.
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_1770
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_1771
STEVE_K
Snohomish, WA
How was the factory oil separator install? Not sure if I found the instructions for the correct kit when I was looking a few weeks back, but the drivers side install seemed to be a pain with the instructions saying that some parts had to be broken to remove? I could be wrong, but curious since it would be nice to have factory parts used for this.
HGHVLTS
HGHVLTS
Sounds like you got the correct instructions, I got the same, says it’s for the Bronco Raptor, but it is identical. The tube on the drivers side almost impossible to remove unless you have a specific tool, maybe a fuel line removal tool would work for the removal. However I broke it on the valve cover, just a couple tiny tabs break. The driver's side was by far much harder than the passenger side, passenger side was quite easy though.
Fuel Removal tool, or something similar, just easier to break the tabs for me since I knew it wasn't going to be used again.
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” 96834_W3
Evilrider
Lloyd
Chester Va
2024 ranger raptor 2022 Explorer King Ranch
Been looking for a bit, finally found a RR near by and pulled the trigger yesterday; great little truck and looking forward to the build and gaining knowledge from this forum.
Love the color. Have fun
got3fords
James
Central Va.
Are the lug nuts on the 6G the same as the 5G? If so, I can just reorder from my Amazon.
HGHVLTS
HGHVLTS
I am not sure, but Amazon would probably have what you are looking for. I didn’t go fancy, Amazon factory style lugs, $30 for the set IIRC. Locks are McGard, they were $60
HGHVLTS
HGHVLTS
A few goodies came in, Focals for the doors along with some sound deadening. Going to try the 3” Infinity Kappa for the center channel, still waiting on those however.
Also ordered a port matched intake manifold and ported 69mm throttle body.
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_1846
HGHVLTS
HGHVLTS
Finally got to the Focals being installed, got some Amazon sound deadening along with Siless 3 in 1. Didn’t do every square in, but turned out really nice. Night and day difference, first vehicle I have ever done deadening on. I will get to the roof at some point along with wiring the driving light on the third brake light.
Ford Ranger HGHVLTS’ 2025 Raptor build “ish” IMG_1848
Pic-N-Stick
Northern Virginia, USA
Retired Firefighter
Let us know what you think of the Focals! I know they need a break-in period, but compared to the OEM fronts how bright are the tweeters? Did you lose any of the mid-base at moderate volume?Still kinda up in the air between these and Kicker components.
