New to the Ranger Raptor Family and I have a couple questions.
Dfdlamson52
Brandon
Massachusetts
2025 Ford Ranger Rapto
Fire Prevention Officer
Just picked up the new truck last week and had a couple questions. Is the driver's side front window the one touch up window or are both front windows? My passenger side is the only one doing it. Was sure if its new and touchy or if there's an issue.
My second thing was I've seen some pictures of trucks with sensors in the sides of the rear bumper. My truck just has them in the back. All in all the truck has been great so far and fun to drive.
fordtrks4ever
Perkiomenville, Pa
You have a 2025 so you no longer have park asst. So no side sensors are needed.
You were seeing 2024 that have park asst. Both windows should work the same.
Dingus83
Oklahoma
Try rolling your window all the way down, then roll it all the way back up and hold the switch up for 1 - 2 seconds after it has gone all the way up and you should hear it click.
Scotty2
19 ranger 24 ranger
Ford
To reprogram the windows you need to hold button down, once window is down hold for 10 seconds then pull button up holding for 10 seconds do this two more times both ways, last one should be in the up position then hit button to activate one touch down let window go down. once down hit button for one touch up. They should be programmed. If not drivers door mod is probably bad bad to dealer
Dfdlamson52
Brandon
Massachusetts
Thank you for the help I will try these suggestions when I get home from work.
