OEM Ranger bed lights not operational?
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
I unlock my truck, it turns on the cargo lights, which turns on the bed lights. I open a door, turns on the cargo lights, which turns on the bed lights. or I can use the cargo light switch, or the zone lighting on the infotainment
So when I first got my truck in april 2017, the bed lights came on with cargo when I unlocked or opened my door. The last update I did about 3 weeks ago, it removed that feature, now they only come on with the manual switch or zone lighting. wtf ford!?!
James C
Scuba Jim
Kentucky
2025 Ford Ranger STX
Good luck on the FORscan, it appears the dealers in my state have no idea what FORscan is... I installed my OEM lights in the bed of my truck months ago... I might have to pay big money to have them switched on in the BCM.
ezetob0725
Zeke
2025 Ford Ranger XLT
Hey Man I was wondering if you ever ended up finding a solution. Having the same problem with my 2025 Ford Ranger XLT. Bought 2 truck bed lights and mounted them to the back of my truck bed where the squares are outlined. I then connected them to the factory wiring harness that had a dummy cap on it right under the rear lower bumper by the wheels on both sides. I tried everything from Forscan to seeing if it was a fuse or maybe even missing wiring by the lower driver side steering wheel. Couldn’t figure out what was wrong. I’m thinking about taking a loss here and returning the lights because I can’t figure out why they won’t turn on at all. Any help would be appreciated
James C
Scuba Jim
Kentucky
I have a guy that was recommended to me from a place that installs aftermarket stereo's and he has brought his scan tools over and was not successful, he is coming back tomorrow to look at if again. The next choice will be taking it to the dealer again. I have also contacted FORD directly and they are going to have a engineer look into it as well.... STILL no luck yet...
bgn
Seattle
2022 Maverick Lariat FX4
https://www.ranger6g.com/forum/thre...24-crowdsourced-spreadsheet.12611/post-515570
I am not responsible if you burn your trucks down. And I don't think my Australian mate that I ripped this from would be either. 😏
ezetob0725
Zeke
Dang nice lol. I assume you have to change that in FORscan right ? Yesterday was when I had a guy come out and use Forscan to try and turn the lights on. Neither of us could figure it out after an hour. I’m gonna shoot him a message and see when he’s available to come back out. If I end up getting it to work. I’ll post a reply.
bgn
Seattle
Correct. It's in the BCM ASBUILT option. Take a picture of your previous value in that field if you need to change it back. And keep in mind recalls and software updates may overwrite it.
Larry Evans
LARRY
Oregon
2025 ranger lariat
Driver
Did you figure out how to get bed lights working? I have tried every forscan edit with no luck.
ezetob0725
Zeke
Nah man. I ended up returning the lights and
Nah man, never got them to work. I figured the thread that the user “bgn” recommended me to try wasn’t going to work because that persons truck was a Lariat trim. Also, I went to take another look and in the wiring harness on the right rear lamp, there’s 4 wires going into the back plug but only 2 come out, meaning that it’s actually missing some wiring to get power to the lights. They must’ve not wired it up in the factory and just had the harness up for looks. Anyway, I ended up returning the lights and buying some lights from Walmart that were like $20 bucks. They had 8 square LED lights with a + and - wire. It was pretty simple to wire and took about 20-25ish minutes or so. If you’d like I can share how I wired them up and how they look.
Larry Evans
LARRY
Oregon
2025 ranger lariat
Driver
That's ok, thanks for the reply
James C
Scuba Jim
Kentucky
Did you figure out how to get bed lights working? I have tried every FORscan edit with no luck.
Hey Larry, I had a guy who programs keys and "other stuff" for some of the dealerships here locally and he tried and tried and tried using FORscan to activate the OEM lights for my 2025 Ford Ranger and he did not get them to work, he left frustrated and pissed off, my next option is to take it to the dealership and just leave it with them, I call FORD and they said that they will have to have an engineer get involved... The Tech. said that that it should have been simple to turn it on using FORscan, but he left mad as a hornet!
