Oil Life Reset Help
MoreRai
I am having issues resetting the oil life indicator from the Vehicle Maintenance -> Oil Life menu. All of the instructions I could find say that I should have an "OK" button there to reset similar to what you see on the trip odometer or resetting the mpg which both work fine. I am not seeing that button and can't for the life of me figure out how to reset it. Am I missing something that should be obvious?
I have tried with the truck running, with the truck in accessory mode, holding down the brake, nothing seems to work. Any help would be appreciated.
Ford Ranger Oil Life Reset Help IMG_1323
RANGER/HOBB
THE WORLD
Retired USAF
This was posted by another forum member and is very helpful;
Ford Ranger Oil Life Reset Help IMG_1704
Raptortugal
Portugal
Ranger Raptor 6g
While playing with forscan I came across it by chance.
I had deleted the OK by modifying in IPC "Oil Change Reminder" or "Oil Minder Distance/Time".
I put it back to original then since the message for RESET had disappeared.
MoreRai
You're awesome, I never would have found that.
Many months ago I changed the Oil Minder Menu from Disabled to Enabled and it must have removed the reset option. This was my first oil change since then so I didn't make the connection to the IPC module that I changed.
Much appreciated for the help.
Raptortugal
Portugal
Ranger Raptor 6g
Perfect, glad it works 👍
Have a good trip.
