powering air compressor with 12v outlet in bed?
Appleman1le
Eddie
Long Island
24 Raptor
Hey guys,
I have a decent 12v compressor that connects to the battery using alligator clamps. If I cut the clamps off and wired the compressor up to a regular 12v plug, would it be ok to use the 12v plug in the bed? Or is it too much load for that circuit?
Thanks
CrudeBacon77
New Mexico
Ranger Lariat FX4
Hey guys,
Thanks
Been wondering the same thing. Gonna keep an eye out on this post.
pablo94sc
Focus
It'll likely pop the fuse. Compressors draw a bunch of amps on start up.
dard6555
The 12v outlets are rated to 20 amps max. If your compressor does not have an amp rating on it, it may state how many watts it uses. Watts = Volts * Amps. So max wattage on the outlets is 240watts.
Ford put 2 extra wiring harness on the Ranger's one is in the front and one in back. I would use this first. It should be located close to the trailer wiring harness on the drivers side of vehicle.
