Signature Lux
Gold Sponsor
Australia
www.signaturelux.com.au
Ranger Raptor 23.5
Your truck can now announce itself every time you open the door—courtesy of our new welcome puddle lights! ✨
You know, just a subtle little reminder. In case they missed the massive grille, the aggressive stance, or you mentioning it 47 times a day. ?
Easy Plug & Play Installation – Because your time is better spent flexing.​
Perfect for Nighttime Exits – Step out like the legend you are.​
Subtle? Nope. Necessary? Absolutely. ?
? Get yours now and let your Raptor remind the world who’s boss – even before you start the engine.
? Shop Now
Ford Ranger Raptor Puddle Light Flex  😎 2EA01003-64A9-425A-AB89-B3FBE37D5193 (1)
Ford Ranger Raptor Puddle Light Flex  😎 9CF7B1F6-FC68-47C8-8FDC-2F3CEC6C427B
Ford Ranger Raptor Puddle Light Flex  😎 IMG_0448
Raptor3TT
Wow, those look awesome. On the website there are 3 options: white, red, or orange. The one in the pictures above is white with red/orange outline. Can you please specify which option that is, because there are pictures of an ALL orange one and an ALL white one. Just want to make sure I order the correct one.
Joejr
Joe
West Chester PA
Do these fit the Ranger Raptor or just the full size Raptor?
got3fords
James
Central Va.
From their website, linked above.
" Enhance your Ford Ranger Raptor with our exclusive "Raptor" Puddle Light Upgrade, available in three striking variants: white Raptor claw, red Raptor claw and orange Raptor claw "
ADDGAMER
Adam
New England
Scientist
Yeah, these will def not clear the stock running boards on the RR. I'm on my second attempt with a company and no amount of adjustment will 100% clear the boards. They even went as far as saying they went back to the drawing board with the development crew to only have the same exact result.
Deleted member 9086
Do US model RR’s even have puddle lights……….? Not attempting to be ignorant, I’ve just never seen them?…………… Location???
Shadow Black Ranger Rapto
St. Louis, MO
Signature Lux
Signature Lux
Gold Sponsor
Australia
Ranger Raptor 23.5
Hi, this puddle light is specifically designed for the Ranger Raptor. We’ve tested and confirmed that larger trucks’s puddle lights, like those for the F150, won’t clear the left side step – and we’re aware of that. However, this one is made to fit the Ranger Raptor perfectly, After several trials, we found the ideal adjustment. It’s already been installed on a few North American Ranger Raptors with great results.
Signature Lux
Signature Lux
Gold Sponsor
Australia
Ranger Raptor 23.5
They are on the underside of the outside rear view mirrors.
I also had to go back and forth with the manufacturer, as the first set was partly obscured by the stock running boards. Sent them pictures and the second set worked.
ADDGAMER
Adam
New England
Scientist
Here is the link:
https://pimpmyev.com/products/premi...dle-approach-lights-for-ford-ranger-2023-2024
this is where I obtained my 2 pairs waited over a month for the "new style" the image was obscured just as much as the first set..
St. Louis, MO
Did you try rotating 180 degrees? Mine only clear the running boards if oriented with text farthest away from truck and then just barely. My avatar photo shows a shadow of the running board at the top.
schapstic
New Hampshire
2024 Ranger Raptor, 2006 Mazda Miata
Home designer
Do you have install instruction available yet? I'm definitely interested in these lights
