Resetting PATS after ABS module swap
dsmclark
Sam
Dorset
Ford Ranger Raptor
Does anyone know the best way to reset the PATS after swapping the ABS module or know of anyone who can connect remotely to do it? I bought a licence for FDRS as forscan couldn’t do it and then it says I need a NASTF log in (after also buying a new obd j2543) to reset it. Currently have a B10DA 51 2B code and the truck won’t start. Sometimes after resetting it will only then to cut out the moment you move the gear selector into drive.
With the old abs module lost the right rear brake. Changed both rear calipers and pads only to find no fluid was coming from the abs module. Looks like a solenoid got jammed shut. No codes but the brake pedal was very soft. Happened just at the end of the warranty. Did speak to ford but they only said they might be able to offer a goodwill contribution and I had to get it to dealer to diagnose. The said dealer were the ones who did a brake fluid change in Jan 2025… so I opted to change it myself. Kinda regretting it now but at least I know it’s fitted right (also at the January 2025 service they over filled the oil by 3l and spilt it everywhere and then scratched the wing cleaning it up, thinking about it when cleaning the engine bay they could have contaminated the brake fluid 🤔).
Just out of warranty and had to spend over £5000 in parts 😂 Rant over any help appreciated :)
