Rough Country U-bolts
p703@25
Joe
2024 ford ranger XL STX 4WD
I’m going to install 1.5 inch lift blocks on the leaf spring on my 24 ford ranger. Doing some research I found that ubolts for axles should be no less then a grade 5 steel but better using a grade 8 steel for off-road fun. I ordered a set of ubolts from rough country. Does anyone know what steel grade rough country’s u-bolts are? I ask them directly they couldn’t tell me. Also, would anybody know the alignment pin size for the lift blocks leaf spring to the axle?
Thanks!
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
The pin size is smaller than previous Rangers I think but I could measure the OEM driver side lift block hole and give you a close estimate if needed, I just know I had to grind down the pin on 3/4" blocks which was max with stock bolts but even that was pushing it close
p703@25
Joe
Yes! That would be extremely helpful if you could provide me with those measurements. I ordered the blocks from Real Truck, and the pins on these are 1/2 inch.
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Yes I think your ok the All Star performance blocks I fitted were claimed as 9/16" and 5/8" pin diameter and I definitely needed to machine them down to fit based on either claims, I don't remember which was accurate for the AS blocks. I would say 3/4" is maximum for OEM hardware. The aftermarket block I used and OEM driver block with dimensions are pictured for reference. I think I was going to make or have made blocks based on the measurements at one point but it would have been a lot for one pair. The center hole diameter on shown OEM block is ~3/4" diameter and features a locating nub as well shown
Ford Ranger Rough Country U-bolts 2f30d3bd70b34b709e7b5d09b62ded2d_1930c902-a838-44bd-b7e4-6509d61fc87c
Ford Ranger Rough Country U-bolts PXL_20260113_134808692.MP
Ford Ranger Rough Country U-bolts PXL_20260113_134825445
