Scooter
Vancouver, BC, Canada
65 Comet, 2011 Ford Ranger
--Machinist
3L V6 Diesel: 247 horsepower (184 kilowatts) and 600 Newton-meters (443 pound-feet) of torque.
Payload and Towing capacity up from previous Gen.
Depending on the version, the latest Ranger has a maximum payload capacity of 1,327 kilograms (2,925 pounds) and up to 3,500 kg (7,716 lbs) braked towing capacity.
2022 Ford Ranger Diesel With 3.0-Liter V6 Makes 443 LB-FT, 247 HP (msn.com)
Ford Ranger ROW 6th Gen Ranger 3L V6 Diesel #'s and Towing and Payload revealed AAVrkyo
Ranger35
N/A
I doubt a diesel option will be available for the US/Canada market but I sure hope so.
the1mrb
Duluth, MN
2019 Ford Ranger, XLT FX4
Aerostructures Engineer
Most certainly won't be, but this at least shows that the frame, suspension, and other underlying components can handle that amount of payload and towing. So as long as the US/Can petrol engine(s) can handle that as well, and the additional regulations don't add too many more safety factors, then we have the potential to get close to those numbers as well.
RayRay11
Ray
Usa
2014 f-150
Military
That payload can’t be right for a ranger, that is F-250 level payload.
Scooter
Scooter
--Machinist
The pervious Gen Ranger NA specs where 1600lbs payload and 7500lbs towing.
bill_AUS
Billy
Victoria, Australia
Senior Eng & Tech advisor
It is, the previous gen in Australia had a max payload of around 1470 kg in single cab-chassis, 4x2 2.2 diesel AT spec. The average was over 1000 kg for dual cab models in lower trims, even with 4x4.
Unlike North America, in Australia we value payload to an equal or greater extent than towing capacity. The people that care the most about towing are those with caravans, most people using them as work vehicles need payload capacity.
Scooter
Scooter
--Machinist
Scooter
Scooter
--Machinist
Its the one item on the NA model I hope on the standard Ranger is that. They come with a multi leaf spring. I think the previous Gen they called the one Leaf a Parabolic spring. If it comes standard with a multi leaf spring I will be happy. I like the 6' bed and the Super Cab. Following Fords models, most likely I will have to improve the suspension for Overlanding. Above a Tremor.
bill_AUS
Billy
Victoria, Australia
Our Rangers have a multi leaf pack with a higher constant load rating, we also have an optional heavier rear spring set (factory optional) to suit a 500kg constant load (I think) available on the XL, it also has revised ESC and ABS programming to suit.
Reactions: Doc
Winger57
Bryan
Seattle
88 Ranger 06 Liberty CRD 08 F450
Aviation
As a Yanky I’d jump at the chance to get a Diesel Ranger! Ive put 160,000 miles on my 06 Diesel Liberty. 2.8L 4cylinder 400 ft lbs of torque tuned and still pulls 22mpg combined with some pretty brisk freeway runs. But I could be appeased with a 2.7L option on a Tremor…. Waiting for my Bronco with that motor hoping not take a full year.
bill_AUS
Billy
Victoria, Australia
Agreed...way too high.
You may not believe it, but in the rest of the world our utes can actually carry things.
