RR 2024-2025 Hood heat extractors part#?
Rclancy1023
Robert
Rhode Island, USA
2025 Ford Raptor Ranger
Security
Does anybody know Motorcraft part#?
I want new pair to experiment on. I put in F150led side marker lights in an I love the look. I was thinking if I could reverse the hood heat vents (face them foward) and install same led marker lights it would look bad ass. It would take some engineering but but it might be possible.
SubZombie
Virginia
First off, have you removed them? I don't think they would install backwards since they are asymmetrical and there are clips and bolts in different areas.
Unlike what people sometimes think I have removed one of mine because it was improperly installed from the factory and they are 100% open and functional on the hood. There isn't a giant amount of heat escaping through them, but they aren't just for looks. I feel like you'd have a ton of water pouring in through them at an angle the inside of the hood isn't designed to handle if you had them on in reverse.
They are also probably too expensive for most people to experiment with:
https://parts.levittownfordparts.co...uZ2VyJnk9MjAyNCZ0PXJhcHRvciZlPTMtMGwtdjYtZ2Fz
DirtDerrick
Nathan
Atlanta
dirtderrick.com
People Person
I cut mine out. Noticed the Ford off-road team was running them open in all the desert races. Maybe you can tell from these pictures if it will work for you or not.
I circled the group of little holes that heat is supposed to go through, they are behind the hood insulation, a thick layer of foam, and somehow heat finds its way through.
Ford Ranger RR 2024-2025 Hood heat extractors part#? IMG_1352
Ford Ranger RR 2024-2025 Hood heat extractors part#? IMG_1353
Ford Ranger RR 2024-2025 Hood heat extractors part#? IMG_1351
Ford Ranger RR 2024-2025 Hood heat extractors part#? IMG_1354
Ford Ranger RR 2024-2025 Hood heat extractors part#? IMG_1092
Ford Ranger RR 2024-2025 Hood heat extractors part#? IMG_1082
