Signature Lux Fog Lamps Received
  • Thread starter Deleted member 9086
  • Start date
  • Watchers 5
Deleted member 9086
Finally received my Signature Lux Fog Lamps. Really well constructed LED, hi/low beam, lamps, all metal casings and adjustable mounts.
They’ve put allot of work in on these fog lamps. Nothing cheap or short cuts and they show it.
I’ll be installing them next week along with their hood lamp kit.
Post more at that time.???
Ford Ranger Signature Lux Fog Lamps Received IMG_2896
Ford Ranger Signature Lux Fog Lamps Received IMG_2897
Ford Ranger Signature Lux Fog Lamps Received IMG_2899
Ford Ranger Signature Lux Fog Lamps Received IMG_2900
81stfacp
CTS
I am following this thread. I received mine as well. As yours is going on a RR, I am particularly curious if the full feature of the OEM fog lights is retained.
ba15996X50
Brant
02’ F150, 911, 944, 928, Z4
Research Chef
They look well built… curious, why the need? I should be getting my RR in a few weeks. Thanks!
Deleted member 9086
Don’t want to add additional auxiliary lamps hanging outside the line of the truck.
These are much brighter then the OEM Fog Lamps. They’re bright enough to drive without headlight. The have both hi and low beam.???
ba15996X50
Brant
Research Chef
How much? This forum is starting to add a lot of dinero to a truck I still don’t have! ?
Deleted member 8167
So I tried to install mine. The brackets interfere with the hard plastic mount everything mounts to. I started doing some trimming to make it work but then just abandoned the effort because there just seemed like lots of interference issues.
These will collect dust on the shelf because return shipping to Australia ain’t worth the hassle.
Deleted member 9086
Working with them on the bracket. There will be an update fairly soon.??
One suggestion; did you try to reverse the lights. Otherwise, use the right in the left and the left in the right? Remember they are reversed in Australia. Might be worth looking at.???
Deleted member 9086
I have the new brackets in hand. It’s going to be a little while before I can install, as we have 8” of new snow on the ground presently.???
Ford Ranger Signature Lux Fog Lamps Received IMG_1454
Ford Ranger Signature Lux Fog Lamps Received IMG_1455
FullSend
Ninjaneer
You may have just seen another post said these are still going to require some modifications and that the differences have been past back on and they will be making further changes. But it's getting closer. I just got mine in the mail, but plan to hold off on the next round.
Odb6909
T
Newby question. How do you toggle the low and hi beams? There a additional switch or is it a double press of of the high beam switch? Thank you for the help and time..
Odb6909
T
Welp. Seems like popping the button twice goes the high beams. Tried a few times to contact seller but zero responses.. Was great during purchase but not so much post purchase..
RRap1
Stew
Honolulu
‘25 Ranger Raptor
Thanks for that!
I may be second guessing a purchase on these
what would be your/an ideal mode of operation? I’m trying to understand having the capability of hi and low beam. Was always under the impression that fogs are either on or off.
Odb6909
T
Maybe I'm nuts, but a second push seems to make it brighter... Like it as there are times, especially at night, when the brighter is better on highway after rain. During daylight, no need.. All subjective..
