Fawnbuster
Did you have to cut any metal or was it a drop in?Might not help that much being a NZ Tremor, but I installed the tailgate toolbox and its working perfect for easy access to tools etc..
How is there a "market" when there is no space/cavity anywhere available to make anything to hold/store things???? Magic wand to come and make space that just doesn't exist would probably be the answer...Truck is definitely lacking in storage space. There is a market.
I had to cut out some of the metal, that was the worst bit lol, but it was easy and the bits you take out are only glued in, so no damage to outer panel etcDid you have to cut any metal or was it a drop in?
There is quite a bit of space behind the seat if you're creative.How is there a "market" when there is no space/cavity anywhere available to make anything to hold/store things???? Magic wand to come and make space that just doesn't exist would probably be the answer...
Ya that would've really sucked if you used a long blade in your saw and could see your feet when the part fell clear lolI had to cut out some of the metal, that was the worst bit lol, but it was easy and the bits you take out are only glued in, so no damage to outer panel etc
I used a grinder to cut out the bits, easy to control depth and straight lines, it was actually alot easier than I thoughtYa that would've really sucked if you used a long blade in your saw and could see your feet when the part fell clear lol
