Tires recommendation?
EdCay
Edward
Tucson
2024 Ford Ranger XLT Supercrew 4X4
I recently installed Ebach Pro Leveling Shocks, came out nice, now to phase two: Tires I want to keep my current rims (I like the Pattern and Finish). I'm at odds with spacers to accommodate a larger tire, such as 31s or so, and advice or experience?
EdCay
EdCay
Edward
Tucson
Did you try any larger tire, like 285/70R17, or would there be clearance issues in width? I must admit that what you did looks good
Johnnypedals
New Jersey
2025 Ford Ranger xl stx
Machinist
I went with Nitto Ridge Grappler on factory wheels. 265/70r17 with 1 inch wheel spacers. No complaints with them.
That looks great. A couple questions. Do you have a lift or front level? Also with that size tire did you need the spacers or just liked the stance? Oh and what exhaust is that
Clay
Clay
Eastern North Carolina
2024 Ford Ranger XLT FX4
Nucor Steel, America’s largest steel producer
I did not try any other sizes. I stuck with what i knew would fit based off of my ‘19 Ranger I had. I have not put a level on yet. With the 265/70R17 Nitto Ridge Grappler I have on stock wheels I had a very slight rub on the upper control arm. The Nitto’s have a somewhat aggressive side wall lug which is what was slightly rubbing when turning sharp. I had already planned on 1 inch spacers to make the tire flush with the finder.
Ford Ranger Tires recommendation? IMG_3793
Clay
Clay
I don’t have a level yet, soon though. I was getting a 1” spacer anyway, but due to the somewhat aggressive sidewall lug on the Nitto’s i had a very slight rub when turning sharp. The exhaust is custom dual exit out of the back. On my previous Ranger (2019) I had the Flowmaster FlowFX system. That isn’t available for the ‘24 plus models. I wanted duals for looks as well as sound. I bought the same muffler that comes on the Flowmaster FlowFX system and had a custom exhaust shop put it in the place of the factory muffler. Then custom exhaust out of the back. Black tips. I wish a company made a dual system for ‘24+. In my opinion it sounds good, at the end of the day it’s a 4 cylinder
Ford Ranger Tires recommendation? IMG_3678
EdCay
EdCay
Edward
Tucson
Looks really good, nice job on the dual exhaust. I like that look, guess I'm old school.
Thank you for the tire info
I like the looks of the 265s on a non Raptor Ranger.
‘Really fills the wheel well nicely.
I believe in my research the 275 is probably the max width you can go on a stock wheel, and still have adequate clearance of the UCAs .
Johnnypedals
New Jersey
Machinist
Ok that's great info on the tires. So i will assume 275/70/17 Nittos should fit without spacers with no rubbing.
That looks great. You wouldn't happen to have a sound clip would you?
Clay
Clay
This is the only video i have, i had to trim it down to upload it. I need to make a driving video. I’ll try to do that soon. As for the sound, of course a phone video doesn’t do it justice. But it is the 2.3 , i know
some people are going to hate on the 4 cylinder sound, but sound is subjective. The guy who owns the custom exhaust shop did a very good work and out the door he changed me $300… i did supply the muffler myself, but the pipe, tips, and labor was 300.
Baja_RR
Ian
Manhattan Beach, CA
@bajarangerraptor / @kermitbronco
President, Consulting Firm
I was in Baja with 2 other RR - one the 275 and one with 285 (I run 37" w/ portals). The 285 had slight rubbing with a small lift.
I can strongly recommend Falken Wildpeak R/T01. Work fairly quietly on the road and superbly off-road. The scalloped shoulders aid with shedding and also help with clearance. I was running Trail Grapplers which were deafening on-road and will never look back.
I also have them on a Bronco for rock-crawling on the recommendation of Trail Militia if you know that crew who wheel stuff above my pay-grade. Hope this helps.
Ford Ranger Tires recommendation? 2
german
Mexico
Ranger
Greetings
I went from 255/65/18 to 285/70/17 with methods 708 et 0 and BF Ko3 on a Ranger Wildtrak, I have to install a leveling kit (2inch), and trim a few of plastic, I dont have issues with the clearence of UCA (attached photo before and after)
Ford Ranger Tires recommendation? 20251219_201116
Ford Ranger Tires recommendation? 20251222_144214
Ford Ranger Tires recommendation? 20251222_144226
Ford Ranger Tires recommendation? 20251222_144120
Ford Ranger Tires recommendation? 20251219_201444
Ford Ranger Tires recommendation? 20251221_164300
Ford Ranger Tires recommendation? 20250923_165142
Ford Ranger Tires recommendation? 20251212_111934
Ford Ranger Tires recommendation? 20251224_080556
Ron Quixote
America
Several
Goodyear Workhorse AT least range LS 265/70/18....32.6 inches. On factory rims and no spacers, no level...100% stock. No rub no trim. Lost .4 mpg. Going to stay raked.
Borla exhaust.
Off topic, but what mud flaps are those?
