That looks great. A couple questions. Do you have a lift or front level? Also with that size tire did you need the spacers or just liked the stance? Oh and what exhaust is thatI went with Nitto Ridge Grappler on factory wheels. 265/70r17 with 1 inch wheel spacers. No complaints with them.
I did not try any other sizes. I stuck with what i knew would fit based off of my ‘19 Ranger I had. I have not put a level on yet. With the 265/70R17 Nitto Ridge Grappler I have on stock wheels I had a very slight rub on the upper control arm. The Nitto’s have a somewhat aggressive side wall lug which is what was slightly rubbing when turning sharp. I had already planned on 1 inch spacers to make the tire flush with the finder.Did you try any larger tire, like 285/70R17, or would there be clearance issues in width? I must admit that what you did looks good
I don’t have a level yet, soon though. I was getting a 1” spacer anyway, but due to the somewhat aggressive sidewall lug on the Nitto’s i had a very slight rub when turning sharp. The exhaust is custom dual exit out of the back. On my previous Ranger (2019) I had the Flowmaster FlowFX system. That isn’t available for the ‘24 plus models. I wanted duals for looks as well as sound. I bought the same muffler that comes on the Flowmaster FlowFX system and had a custom exhaust shop put it in the place of the factory muffler. Then custom exhaust out of the back. Black tips. I wish a company made a dual system for ‘24+. In my opinion it sounds good, at the end of the day it’s a 4 cylinderThat looks great. A couple questions. Do you have a lift or front level? Also with that size tire did you need the spacers or just liked the stance? Oh and what exhaust is that
Ok that's great info on the tires. So i will assume 275/70/17 Nittos should fit without spacers with no rubbing.I don’t have a level yet, soon though. I was getting a 1” spacer anyway, but due to the somewhat aggressive sidewall lug on the Nitto’s i had a very slight rub when turning sharp. The exhaust is custom dual exit out of the back. On my previous Ranger (2019) I had the Flowmaster FlowFX system. That isn’t available for the ‘24 plus models. I wanted duals for looks as well as sound. I bought the same muffler that comes on the Flowmaster FlowFX system and had a custom exhaust shop put it in the place of the factory muffler. Then custom exhaust out of the back. Black tips. I wish a company made a dual system for ‘24+. In my opinion it sounds good, at the end of the day it’s a 4 cylinder![]()
This is the only video i have, i had to trim it down to upload it. I need to make a driving video. I’ll try to do that soon. As for the sound, of course a phone video doesn’t do it justice. But it is the 2.3 , i knowOk that's great info on the tires. So i will assume 275/70/17 Nittos should fit without spacers with no rubbing.
That looks great. You wouldn't happen to have a sound clip would you?
GreetingsI recently installed Ebach Pro Leveling Shocks, came out nice, now to phase two: Tires I want to keep my current rims (I like the Pattern and Finish). I'm at odds with spacers to accommodate a larger tire, such as 31s or so, and advice or experience?
39 lbs per tire stock tires were 34lbsGoodyear Workhorse AT least range LS 265/70/18....32.6 inches. On factory rims and no spacers, no level...100% stock. No rub no trim. Lost .4 mpg. Going to stay raked.
Borla exhaust.
Off topic, but what mud flaps are those?Goodyear Workhorse AT least range LS 265/70/18....32.6 inches. On factory rims and no spacers, no level...100% stock. No rub no trim. Lost .4 mpg. Going to stay raked.
Borla exhaust.
