Where to wire RTO
GrimRR
JON
Ab
2025 SGM RR
Just wanted to see where people are wiring a RTO to for a switched source. I have read fuse 35 under the dash and have read seen few other locations mentioned (but I can't find now) so I wanted to see what the options are. Thanks for the help.....
bigb
Tucson
2025 Ranger 2.7
I think it's a "Run take off" source for power. If you remove the left side footwell trim there is a dedicated customer use wire hidden away behind the harness (there are actually several, one is for ignition switched power and the others are for various lighting when the truck is upfitted). The switched ignition source is fused at 10 amps and is intended to be used to power relays that will switch your accessory loads that you run battery power to, it is not intended to directly power accessories.
You want the green one with the white stripe.
GrimRR
JON
Ab
2025 SGM RR
Thats the one I was thinking of, thanks!
OxygenMask
Phil
Eugene, Oregon
2025 Ranger Raptor, 2012 F350
What is an SGM RR?
