craigc
Craig
Allen, TX
There have been several threads about FORScan, but would like to consolidate into one place like was done for the 5G Ranger.
The below document will be updated as people give confirmation as to what works and what does not. I am hoping to find GUI changes as Asbuilt changes together if possible, like you will see on the Confirmed tab for the Chimes and Bambi mode
Web version: FORScan NA Ranger 6G
Actual Gsheet: FORScan NA Ranger 6G - Gsheet
The 3 most useful tabs:
  1. Features Confirmed - these are options that are proven to work on the Ranger
  2. Features TBD - these were collected from F150, Ranger5G, and Bronco and need to be confirmed
  3. FORScan GUI - this is a dump of all the options for all NON-ASBUILT module pages in FORScan while connected to a 6G Ranger
IF YOU CAN CONFIRM a configuration change works, if you could post to this thread with this information:
  • Feature name from the Feature Tab
  • What value you changed from -> to (asbuilt only, or GUI)
  • Ranger trim level tested on
  • Any side effects or gotchas when making the change
  • Any other details of what the feature actually does (in layman terms)
Please PM me if you would like to be an editor for this sheet or request access from within the Gsheet.
** NOTE ** The sheet may take some time for changes to get entered after there are posts with confirmations. So be patient please :)
jedadiah
Jed
Kentucky
For the seatbelts, which one just gets rid of the need to press ok? I'm fine with an alert, but get tired of hitting that button.
My only other annoyance is the "full view not available" prompt. My XLT only has one camera. There's nothing more to show, so get out of my view :)
I need to renew my Forscan license. I used it on my 5G, but that's been a while.
craigc
craigc
Craig
Allen, TX
I'm not sure yet. I hope to some day find out, but at this point, it'll take some manually tinkering with those bits to see. If anyone finds out, hopefully they will post it and I'll put on the sheet. I too would just like to remove the OK or the warning that will never go away if you unbuckle once buckled.
I believe there is a setting for that.. Look at on the TBD tab. I have not tried yet though.
Stumpm2
Wyoming
Ranger Raptor, F350 Tremor
Below is what I have changed and verified works on my 2024 Ranger Raptor NA:
BdyCM Plain English
Using Front Fog with High Beam, 1-inhibited to 0-allowed
jezzza
Jezza
Brisbane, AU
2022 Ranger Raptor
‎‎ Engineer
This is what I've changed so far, all working successfully on 2022 Raptor.
(Sorry havn't got time to adhere to formatting.)
BdyCM
Honk leaving cabin - Disable
Fog Lamp Usage = DRL
DRL with turn signal = Dimmed
Power Point timeout - 7200s
APIM
Silent Mode Control - Enable
Auto Lock Control - Enable
DRL Control - Enable
SCCM
Lane Change Blink = 2
IPC
Drivers Belt Minder - Disable
Passenger Belt Minder - Disable
Trailer Tow Backup - Enable
Menu Tow Haul Auto - Enable
Chimes Running/Open - Disable
Turn Signal Volume - Enable
Turbo Boost Gauge - Enable
Tyre Temp 720-11-01 [xxxx-Axxx-xxxx]
PD Gauge 720-07-01 [xxxx-8xxx-xxxx]
Welcome Lights
BCM 726-45-01 [xxxx-xxxx-x1xx]
APIM Approach Detection Control
BCM Approach Detection - Vehicle
Einhander
Cary
Los Angeles
2022 Ford Bronco Wildtrak
Special Effects Technician
Raptor1996
Anton
Ohio
I've poked around and haven't had luck finding it in this consolidated spreadsheet... is there a place for heated steering wheel output power? I started another thread over the weekend and lots of people made it sound like it was an extremely straightforward parameter to modify.
craigc
craigc
Craig
Allen, TX
wow that's a lot of things. Some of those I have no idea what they even do. I wonder if any of those are specific to Australia or only needed on 5G vs 6G. can you advise on what these do?
jezzza
Jezza
Brisbane, AU
2022 Ranger Raptor
‎‎ Engineer
Not specific to Australia, same vehicle. Not sure about 5G, that is a different vehicle.
Power Point timeout - [12v outlet power off (seconds) after AUX is off]
Silent Mode Control - [same as dark mode or police mode]
Auto Lock Control - [settings option for door lock at 15mph]
DRL Control - [settings option for day time running lights]
Trailer Tow Backup - [enabled from factory on newer (US) models]
Menu Tow Haul Auto - [enabled from factory on newer (US) models]
pablo94sc
Focus
What is silent/dark/police mode, and what does it do?
jezzza
Jezza
Brisbane, AU
2022 Ranger Raptor
‎‎ Engineer
No interior lighting when you open doors, interior lights have to be turned on manually.
Exterior lighting too. It's actually surprisingly handy when not wanting to disturb others when camping.
craigc
craigc
Craig
Allen, TX
Too bad that's not a sync option. I like having the exterior lighting most of the time, but wish could have easy way to turn on/off silent mode using the panel or a switch rather than Forscan. Helpful while camping as has been stated...
FYI I have updated the link at the beginning of this thread to have the actual google sheet link rather than just the web view which doesn't allow filtering.
