Which spacers did you use? Did you get 2" lift with the 1" spacer?
dmurphey13
dmurphey13
Dakota
Augusta, GA
2024 ranger xlt
I used the super lift 2.5 level and the spacers were titan brand
PAW
Peter
Knoxville Tennessee
2025 ranger ordered
Driver
Not quite following on the cutting of studs. Can you please explain if you have time and would love a side view of this lift. Thinking about using the superlift. Did you use supplier sway bar drop links?
dmurphey13
dmurphey13
Dakota
Augusta, GA
2024 ranger xlt
So the spacers are only an inch so the studs in the back are longer than that so like three threads come through on the mating surface so most people cut them off, but the xlt wheels have pockets that the studs will fit in them. I did use the sway bar drop links with no issues.
PAW
Peter
Knoxville Tennessee
2025 ranger ordered
Driver
Thank you much.
danmoochie
dan
florida
retired Sales manager
Put 1 inch spacers on and it rides great! The back studs are longer than the fronts and will need to be cut or with the xlt wheels, they fit in the pockets.
So if I ordered my 2025 XLT FX4 and go with one inch spacers the rim can accommodate with any stud cutting front or back?
embedded rock
Earth
WITHOUT cutting studs, correct?
Probably so, but it seems the lug nuts have to have some space inside to accommodate.
danmoochie
dan
florida
That's why I was asking him. He's done it.
OHTREMOR
Ohio
2024 White Lariat FX4
Looks great.
