2025 Ford Ranger Lariat – Lane Assist Canceling
Dragline
Virginia
2025 Ranger Lariat
After completing oil service, tire rotation, and troubleshooting an uncommanded 4WD issue (with the required part on order) at Dealership on April 1, 2026, I engaged cruise control during my drive home. The driver assist screen intermittently illuminated and displayed a “canceled” message. This occurs repeatedly with cruise control and driver assist activated.
5 May 2026 – Ranger at the dealership for Lane Assist cancelling, replaced IPMA camera, issue not resolved.
12 May 2026 – Ranger at the dealership for Lane Assist cancelling, reprogramed, however got a few miles down the road and it happened again, back to dealership, harness on order. Issue not resolved.
10 June 2026 – Dropped off Ranger at the dealership for Lane Assist cancelling.
17 June 2026 – Pickup from dealership, Lane Assist, repaired/replaced wiring, and it happened again, happened 5 more times on the way home.
23 June 2026 – Dropped off Ranger at the dealership for Lane Assist cancelling.
29 June 2026 - Pickup from dealership, Lane Assist, repaired/replaced wiring, did not even make a few miles down the road with CC set at 45MPH and it happened again, took it back to the dealership. It happened 3 more times on the way home. (Had to take it home as we were leaving on vacation)
21 July 2026 - Dealership appointment, if it is not fixed this time, I am considering Virginia's Lemon Law approach.
The problem is really aggravating as you cannot use the cruise control without this cancel message appearing numerous times and randomly. Anyone else have this problem?
Ford Ranger 2025 Ford Ranger Lariat – Lane Assist Canceling 1784384893495-9g
rugedraw
Javier
Miami, FL
Auto Sales
Do you have FORScan or any kind of code scanner to see what codes it is reporting?
Dragline
Virginia
2025 Ranger Lariat
Dealership said U3000 in the IPMA, performed hardware test - passed, Perfromed PMI on the IPMA and recalabrited the cameras and retested, no DTCs , all systems passed.
Corrupted memory in the IPMA.
Retruned after test drive, replaced IPMA camera and performed camera alignment, test drove to verify repairs.
Wayfaring Ranger
STL
I see the cancelled message occasionally pop up, but it always seems to be when the highway lines do something different. For example, being in the right lane and going passed a highway exit, the truck loses the white lines on the passenger side so it cancels the lane aids until it can find the lines again and re-calibrate.
Dragline
Virginia
2025 Ranger Lariat
Mine does it randomly on the interstate also with straight highway lines. It happens so frequently that I can't even use the CC. Never happend when I bought the Ranger April of 2025 and started happening April 2026, almost a year later...
rugedraw
Javier
Miami, FL
Auto Sales
If your truck is connected to the Ford app, message me the VIN so I can pull the codes.
Is it lane centering or lane assist. And if you have something else displayed in the center window, like trip information, do you still see the message?
rugedraw
Javier
Miami, FL
Auto Sales
Got your message; responding here for the sake of the info being out there. Your truck is reporting this code in the PSCM intermittently. This code will 100% cause issues with driver assist features. Every time the code surfaces, the sub type is 00 which makes this impossible to diagnose remotely. Dealer would need to run pin-point tests to see what's causing it. Codes are stored for 60 days at a time in Ford's cloud and in the past 60 days, there have been no IPMA codes reported.
Ford Ranger 2025 Ford Ranger Lariat – Lane Assist Canceling 1784391264068-b6
Dragline
Virginia
2025 Ranger Lariat
Thank you so much for doing this, much appreciated. I will relay this info when I take the truck in Tuesday.
Dragline
Virginia
2025 Ranger Lariat
Lane assist and happens on other screens as well...
snowman3
us
none
Thx for helping OP! What system or DB are you accessing? Can all dealers or independent mechs see it? Would be fantastic to remotely diagnose issues before even take to dealer. Wouldn't/Couldn't that cloud download be first step when doing their "50 point inspection"?
KStiff
Keith
Kentucky
Ford Ranger
Are you wearing your seatbelt? I discovered lane centering only works if you are wearing your seatbelt!
rugedraw
Javier
Miami, FL
Auto Sales
That info is visible in Ford's PTS/OASIS website. All Ford dealer service employees have access to it.
It's available to anyone if you're willing to pay for the access.
the reason I ask is lane is always enabled even when not in cruise control.
you can set the amount of assistance but you can’t turn it off.
