2025 XLT, which engine?
Helimech
Joel
New Jersey
2018 Subaru Crosstrek
Helicopter Technician
Good evening,
New to the forum. I'm going to be buying a 2025 XLT early in 2027 to replace my subaru crosstrek, the last Ranger I owned was a 1998 XLT with the 4.0L. Things have changed quite a bit drivetrainwise since then and I wanted some opinions on the two different available engines. I mostly drive about 25K a year, (80% highway) and perhaps 10 times a year or so I will be towing my Tracker Tournament V18 bass boat (up to 500 miles per trip). It comes in around 2200 lbs. I've read all about the towing capabilities of both drivetrains and they both seem more than adequate. Is it worth the slight loss in MPG for the higher HP/torque of the V6 vs. the inline 4? Obviously the additional power means less wear and tear on the engine in the long run. But as I stated above my experience was with the 4.0 which far outperformed the '89 XLT I had with the 2.9L 4 cylinder. Is the 4 cylinder high revving, does it sound/feel like it struggles compared to the 6. Any comments would be appreciated.
Joel
OxygenMask
Phil
Eugene, Oregon
2025 Ranger Raptor, 2012 F350
I'm sure the 2.3 owners will chime in, but for your situation I would absolutely get the 2.3. It's an exceptionally good engine and fights well above its weight. Turbo is a game changer!
Look at the power numbers, 20 years ago that was v8 power! Lots of stories on here about road trips towing seriously big trailers just fine.
Also the highway mileage is a lot better than the 2.7, not just a little bit.
And then, 2027 will drop the 2.7 and will be a 3.0 v6. Details not well known. Not a fan of being an early adopter, especially with Ford....
GEN3SKI
West
Ranger Raptor, Bronco Raptor
except the ford ranger already has a 3.0 option. And it’s a very known engine.
got3fords
James
Central Va.
With any amount of towing in the forecast, I would totally opt for the V6. The 3.0L is not a new engine and is well-proven. And with a tune, it will really come to life.
OxygenMask
Phil
Eugene, Oregon
Wrong engine. The standard Rangers won't be getting the RR engine. Everything I've seen points to a 3.0 version of the 2.7. Even so, if it is merely a lower performance version of the RR 3.0, how many bugs will likely need to be worked out? Ford has a poor track record on stuff like that...
surfstar
CA
2025 Lariat 2.3 FX4
2.3L is plenty [HP] and the 2025 is the updated one with port and DI.
If you find a deal on the right truck, buy it; with either engine. Buying used is more about finding the right truck - price, miles, maintenance, etc that you want and being flexible on items that you can go either way on.
surfstar
CA
2025 Lariat 2.3 FX4
Psst - there is no 3.0 non-RR in 2025. OP says he wants to buy a 2025 in 2027 - not a 2027 Ranger!
Reading comprehension people!
artvarck
Art
CO
2025 XLT 4WD
Retired (FIRE)
As the owner of a 2.3, I say go for the V-6. I haven't towed, and the 2.3 does have plenty of around town "omph*, but the small MPG difference isn't worth the loss of low end grunt.
