360 camera view is small now - help needed
EzequielArgentina
Ezequiel
Buenos Aires, Argentina
Ford Ranger T9 2024
Auditor
Hello
I have been playing with forscan and scanner in my Ranger and I have some good news and bad news..LOL
I was able to enable drive modes such as sport, rock and crawl.
I was able to add the compass and the GPS indications to the screen behind the wheel
I was able to keep DRL on while using turning lights
I was able to keep back lights (the red ones) while driving only with DRLs
I was able to add the tyre temperature (it only showed pressure)
I am still trying to enable the way to get the # of gear constantly visible (i can only see it if I press + or - buttons in the gearbox)
I modified the FOG LAMP usage to: FOG ONLY, it was set as CORNERING LIGHTS
bad news:
I was working with a 360 camera view setting that initially displayed "UNCONFIGURED OR PARAMETERS NOT SET" and functioned perfectly with the camera views filling the frame properly.
However, I decided to experiment with the other available options: "VERTICAL TOP," "VERTICAL," and "HORIZONTAL." After testing all three settings, I discovered they all render the 360 image significantly smaller than the frame, creating unwanted empty space around the image.
Now I'm trying to revert to the original configuration, but the "UNCONFIGURED OR PARAMETERS NOT SET" option is no longer available in the dropdown menu - only the three problematic options remain visible.
How can I restore the original setting that properly sized the 360 image to fill the frame? Any assistance would be greatly appreciated.
RonM_TX
Ron
Conroe Tx
Hello
bad news:
You can revert back to your original settings by restoring the backup you made before you started modding the settings. You know what setting you have working so it would take no time to change those.
EzequielArgentina
Ezequiel
Ford Ranger T9 2024
Auditor
I havent backed up!! :( this is how it is looking now, you can see that the 360 area is smaller than the black frame. it did not fit the whole screen but the black square.
Ford Ranger 360 camera view is small now - help needed IMG_2081
Yup, you either go through the asbuilt module for what ever changed that and conpare it to your original saved settings, line by line, or you reload your stock saved profile and redo the other stuff that you want
