3rd brake light chase lights
RaptrJr
FL
Wanting to get chase lights for my RR preferably ones for the 3rd brake light area like the ones RPG, GJ Motorsports or Bulletproof Diesel offer. Anyone know if any of those will fit or any other options?
mtesni
CT
24 Ranger Raptor, 23 Bronco Badlands
Ford Ranger 3rd brake light chase lights 1000002398
GJ Motorsports 3rd Brake Chase setup works.
Machduty
Chicago
2024 subaru outback wilderness, 2018 superduty,
Bricklayer
How and where did you run the wires. They are local to me was thinking of picking one up.
mtesni
CT
Ford Ranger 3rd brake light chase lights PXL_20241005_194407330
Ford Ranger 3rd brake light chase lights PXL_20241005_202510836
Ran the wires through the factory opening. I ran them to the right side making sure to avoid the airbag based on installation instructions for the F150's, I would not follow my lead on this haha... F150's have their BCM and Aux wiring leads under the dash on the passenger side which we do not have. I didn't feel like re routing so I just ran a wire from the passenger kick panel to the AUX 1 lead under hood for the chase lights. I'm trying to get the pinout for our BCM so I can enable the center light on reverse.
Machduty
Chicago
Bricklayer
Great thanks for the heads up I have the same setup on my superduty wish it was as simple to install.
RedNose1
Saud
Dubai
Ranger Raptor 2023, Gen 3 Raptor
Is this the F150 kit?
mtesni
CT
Garaged
Usa
Ranger raptor 2024
mtesni
CT
What choices did you make for the three lights?
Also, as it stands now, without identifying BCM, do the little red dot lights still light up on braking?
Went with Sport Wide Cornering in Amber for the outers and Sport Work/Scene for the inner one. The outers I wired up to the Aux 1 switch, inner takes the place of the factory cargo light. Once I figure out the BCM I'll also have it come on in Reverse. The three small lights function as brake lights. The brake lights and cargo light plug in using the integration harness that's included
RaptrJr
RaptrJr
FL
Awesome! I also spoke with RPG and their 2nd gen light will work as well. I’ll be going with either that or the GJ. Did you get a LVJ harness as well? If so I’m guessing the basic w/ reverse based on your other replies
