Added Some Valve Stem Extensions
RANGER/HOBB
THE WORLD
Retired USAF
I know for some this is a minor issue; deep set valve stems. Yes, I know they are this way for a reason. However, on the road it’s a pain in the arse for servicing. The valve stem extension permit ease of access for servicing. You can find them on Amazon and are 27mm;
https://www.amazon.com/dp/B0D3XF9TKV?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
This brought the valve caps up to just a little over level, with the wheel stem recess as pictured. I added oversized, Ford Raptor Valve Caps for ease of grip astatic value and can now service them much easier.
With the stem extensions, you can use any type of air chuck service tool, instead of a just a straight chuck tool.
Anyway, a simple easy modification, that can be reverted quickly if you’re off roading and worried about damaging a valve stem.👍🇺🇸
Ford Ranger Added Some Valve Stem Extensions IMG_1236
Ford Ranger Added Some Valve Stem Extensions IMG_1234
Ford Ranger Added Some Valve Stem Extensions IMG_1235
Ford Ranger Added Some Valve Stem Extensions IMG_1233
Ford Ranger Added Some Valve Stem Extensions IMG_1237
AlpineBike
Andrew
Waitsfield, VT
You are much better off getting an extension adaptor and carrying it with you instead of leaving those attached to your valve stems at all times.
Just like your gas tank fill adapter.
EricNC
Eric
N. Carolina
‘24 Ranger Raptor
That's a good point; I'm not sure why I didn't think of that other than "Duh." LOL, that's what I'm going to do.
Eric in NC
EricNC
Eric
N. Carolina
‘24 Ranger Raptor
Thank you for sharing the link; I'm going to get some. I changed out my air gauges to straight connectors, and my portable compressor already has a straight chuck on it. These will make life even easier.
Eric in NC
patc890
Patrick
Rockville, MD
I had the same problem when I spent a week at the Outer Banks fishing. You have to air down each time you go on the beach. I bought the same ones as you did but didn't like them. I didn't think the spring in them was very good. I found these better and used them all week at the beach.
https://www.amazon.com/dp/B0C36HSZCG?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
I also bought a long extension but feel it's too long, I'd rather a shorter and more rigid one.
https://www.amazon.com/dp/B0BSNSBVYT?ref=ppx_yo2ov_dt_b_fed_asin_title
And I bought the Raptor caps that you have.
RANGER/HOBB
RANGER/HOBB
THE WORLD
Retired USAF
Thanks for the post and link. I like the slightly shorter ones you’ve linked too. Ordered a set.👍🇺🇸
RANGER/HOBB
RANGER/HOBB
THE WORLD
Retired USAF
RogueLobo
Ron
Pittsburgh PA
Do these stick out past the face of the wheel as much as the amazon one?
RANGER/HOBB
RANGER/HOBB
THE WORLD
Retired USAF
Haven't received them yet don’t know until I do. I can tell you 25mm units do not, only the cap.🫵🇺🇸
Clump
Charlie
NEPA
I bought the same extensions as @patc890.
I was at the Outer Banks last week. Airing down was OK. Currituck County has an air up station that's very convenient. The extensions did not work at all with the air chucks they have. I had to remove the extension, fill the tire, then put the extension back on to use my gauge. It was a PITA.
I bought these - https://www.amazon.com/dp/B09VSTFJPZ?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
for temporary use.
I'll remove the extensions and hopefully the Raptor valve caps (+100HP) will work without them.
patc890
Patrick
Rockville, MD
for temporary use.
I had no problem with air station in Frisco? Either way they are a pain.
RANGER/HOBB
RANGER/HOBB
THE WORLD
Retired USAF
Forgot to follow up, apologies;
Miltons work great. No issues and easy access to the stem. They were a fraction longer than what I pictured with the others.👍🇺🇸
MulchBags2
RANGER/HOBB
RANGER/HOBB
THE WORLD
Retired USAF
