Pirategrad
- First Name
- Clem
- Joined
- Feb 4, 2019
- Threads
- 0
- Messages
- 103
- Reaction score
- 40
- Location
- Austin, Texas
- Vehicle(s)
- 2024 Ford Ranger Raptor
Well, if they won’t rework their stock to fit and are just going to provide guidance on how to mod them, it sounds like there is a market to resell modded, ready to go kits. I’d be slightly concerned about warranty if it requires user modification to the lights but it sounds like they have a pretty good reputation for warranty with their current product.
Thanks for getting that statement from them. So far all they have said is they fit and users have been happy with them.
how did you drill out holes to pass the wire through. I watched the video and it says use a 1/2 bit but it rubs and the bit rub oThey do not insert at all. Photo of test fit, but I also did flip it and tried the actual side. They are not tapered so doesn't matter, was trying to make sure the wire wasn't keeping it from pushing in. Confident the bit of red tape covering the adhesive is not the culprit. These clearly are not made specifically for the Ranger and should not be advertised as so. Disappointing considering the premium price. Hopefully they will cover the return shipping due to their false advertising.![]()
How were you able to drill out the hole to pass the wire through. The video says to use a ½“ bit but it barely fits in the middle port and rubs. I worn off some of the plastic on the bottom edge. . The other two are a no go. I drilled pilot holes but I can’t drill out so that the connector goes through. Kinda PO’d because I should have done more research.They do not insert at all. Photo of test fit, but I also did flip it and tried the actual side. They are not tapered so doesn't matter, was trying to make sure the wire wasn't keeping it from pushing in. Confident the bit of red tape covering the adhesive is not the culprit. These clearly are not made specifically for the Ranger and should not be advertised as so. Disappointing considering the premium price. Hopefully they will cover the return shipping due to their false advertising.![]()
