Any way to have bed lights automatically turn on when I open the tailgate?
CrudeBacon77
Ranger Lariat FX4
Is there a way to have the truck bed lights automatically turn on when I open the tailgate? Or a button to do so other than the one by the driver seat?
RangerDangerStranger
SF Bay Area
2024 XLT 4x4 in GreyBlue.
Cool Dude
If it's just a button, you could parallel off of it, 2 wires to a contact type button that rests against the tailgate. When opened, it would activate. So, yes you could do it, but it's not a BestBuy type install.
HyperM3
Lawrenceville, NJ
I think there might be a way in forscan to code that in. Now you got me interested in figuring this out.
HyperM3
Lawrenceville, NJ
It's not an option, So, how are you gonna enable something that doesn't exist?
There could be an option to enable a trigger to turn on the bed lights when it recognizes the tailgate has been opened.
fordgt
You can buy aftermarket LED kits that either have an on/off switch that fits the existing hole near the electrical outlets. Run a positive up to the battery and hook it to the switch. Then run your lights.
there are other kits that have a contact switch. The instructions involved drilling holes in the tailgate and/ or body. I lost interest in that so I don’t know much about it.
DesertBumAZ
AZ
24 RaRaptor
InfoSec
If the bed lights turn on with zone lighting, there might be a way to get them on with the exterior curtesy lights
fordgt
I ran my new bed lights with power from the battery. There is a programmable switch up near the battery and I have a remote on my keychain and one just inside my tailgate. They can be programmed to turn on/off or on up to 99 minutes..
craigc
Craig
Allen, TX
what do you mean by programmable switch? where is this located? Can you share what lights you purchased that include the remote?
fordgt
My lighting project is custom built not a kit. The lights are 12” Kingpin lights. I bought a couple switch kits from Amazon to determine what I needed. One switch is not waterproof. I went with that because it is programmable. You can set it to be on/off or on/ off after a set time. (Couple seconds to 99 minutes I think). The other switch set had 2 waterproof switches but they were strictly on/off. Turns out the remotes for that kit can be programmed to work with programmable switch so I am going to keep both sets. They are $20 or less per set. I mounted one in the taillight area and one on my keychain. The one in the tailgate is currently set for A on/2 minutes and B on/off.
I wired the switch I am using up near the battery where it should be fairly well protected and covered all the terminals with dielectric grease.
Ford Ranger Any way to have bed lights automatically turn on when I open the tailgate? IMG_5982
Ford Ranger Any way to have bed lights automatically turn on when I open the tailgate? IMG_5961
Ford Ranger Any way to have bed lights automatically turn on when I open the tailgate? IMG_5976
RacerX
Bronco
This isn't for the factory lights, but aftermarket led strip with magnetic sensor on the tailgate.
Jeffola
Southwest Florida
Business Development
how about a mercury (tilt) switch inside the tailgate?
Viperpilot
Bill
2008 Honda Civic, 2004 Nissan Frontier
Fed Govt
I have not accomplished this, but my plan is to use a tailgate magnetic switch and install similar to this video but try to tie it into the pre-installed Ranger Raptor aux switch wiring first without running a line to the battery.
