Anyone use this brand for Raptor decals?
25Dsand
Sioux falls
2025 ranger raptor
usps
CoastieN70
Lee
Travelers Rest, SC
Retired U.S. Coast Guard
I too have Rocky Mountain Graphics on my RR.
BTW, installing these graphics, be they Rocky Mountain or some other company's, is not as easy as most people think. It is doable but takes patience and finesse.
25Dsand
25Dsand
Sioux falls
2025 ranger raptor
usps
Thanks I will take a look on Etsy
Chippewa76
Midwest
Ford Car, Truck, & SUV
What these guys said. Rocky Mountain Graphics.
Their graphics are also Authorized by Ford.
Follow the directions. Be patient. Do it in the shade. I marked out the area with blue tape and used a small credit card sized plastic card with thin fabric on it to remove almost all the bubbles. I had gotten it years ago for window tint. I suppose a small firm rubber squeegee would work too.
As I looked down the length of the graphic, I used my fingers to press out the remaining tiny water/air bubbles out of the edges. Start on one end, work your way down to the other. Then go back and look again. Be patient.
Because I was able to push out all the tiny water/air bubbles out with my fingers, I did not have to use a pin. I really wanted to stay away from doing that and was successful.
NOTE: When you apply the graphic, IF you pull or push the graphic hard, you can accidentally reposition it on the truck and not know. Ask he how I know. I had a “redo” on one side. But again, they look perfect.
IDK, instead of using painters tape, which was a pain because it doesn’t adhere that well, maybe I should have made a few marks with a sharpie. Then after I was finished, use IPA to remove the sharpie.
ScoMay23
East Tennessee
2025 4Runner TRD PRO (Mudbath), 2026 Ranger Raptor (Carbonized Gray)
I ordered from Rocky Mtn Graphics based on previous positive reviews that I had read. The decals I received looked pretty cheap. There were numerous imperfections in the printing. I decided NOT to use them.
Ford Ranger Anyone use this brand for Raptor decals? IMG_7079
Ford Ranger Anyone use this brand for Raptor decals? IMG_7077
Ford Ranger Anyone use this brand for Raptor decals? IMG_7076
Ford Ranger Anyone use this brand for Raptor decals? IMG_7075
pohnz1
Christian
Pa
25 Ranger Raptor
Those are air pockets. Mine looked the same. I've had 3 different sets from them. No issues with anything. Look closer. They're fine
Chippewa76
Midwest
Glad you posted this.
Exactly what Pohnz1 said above and I quoted below.
Mine looked the same too. There is nothing wrong with those graphics. What you're looking at is the air gap between the top application sheet and the double thickness outline layer. They are not cheap.
If you have any questions, give RMG a call during their business hours. I believe one of the guys I spoke to was John. Great guy, very helpful. IIRC, he was the owner.
Follow the application directions from RMG.
Also use the info I posted above for reference. Especially getting the tiny air bubbles out with your fingers. It's worth it. Just be patient. It'll work out just fine.
ScoMay23
East Tennessee
Appreciate the guidance. I did not want to take the chance of peeling off the sheet to see if it was a bad print job or dust or, as you said, air pockets.
As it turns out, the truck is getting PPF’d and my installer is making some custom decals. The decals will go on the outer surface. I was told they need to add some kind of adhesive supplement to the outer surface of the STEK DynoShield film (which has ceramic in its outer layer) to get the decals to properly adhere.
I look forward to seeing the finished product: flat black lettering+carmine red trim line on my Carbonized Grey RR.
25Dsand
25Dsand
Sioux falls
2025 ranger raptor
usps
Thanks for all the help the place that did my window tint will be doing the install for me I do not have the patience and my ocd of being to perfect will get to me.
