Raptor Family
- First Name
- Jeff
- Joined
- Apr 2, 2025
- Threads
- 6
- Messages
- 185
- Reaction score
- 291
- Location
- Dallas, Texas
- Vehicle(s)
- ‘25 Ranger Raptor, ‘97 Jeep Cherokee, ‘24 Lexus NX450h+
- Occupation
- retired
Your mounting ingenuity saved money and allowed the better compressor as compared to the premade kit.
I did see the kit you referenced and thought about going that route. However, I wanted to go with the new ARB Brushless compressor, plus I didn’t like the location of the air chuck. So, I did something similar…I went with the brushless compressor and mounted it in the same location, but I ran the air chuck and switch to the rear of the bed. So, far I like it and it is working well for my needs.![]()
The location of your switch is where I was going to put mine—did you use an upfitter switch to feed it? So you can control it from the cab switches (primary), and view the fault codes and second shut-off from bed? Is your truck a 25 or 26 model—I ask because it appears as if no factory 12v receptacle was on the panel. I have 25 with no 12v either, but I just bought a new panel for $82 with the receptacle and if you look closely at the wire harness/ connector by my air tank pic—you see I have a purple and black wire which the new panel has a pigtail that plugs into it. Some trucks are still pre wired for it even though they don’t have it on the panel.
