Auto DRL + dimmed lights gone - FORSCAN
w_zsolti
Zsolt
Hungary
Ranger Wildtrak X
Contractor
Hey guys!
I was just playing with DRL settings, and now im totally confused. Can't turn on DRL, in any ways. Is there any default settings for the headlights?
Headlamps are normal LED, not the performance model.
Of course i didn't make a backup from factoy settings.
Any idea, how to get back the lights?
Thanks!
Ford Ranger Auto DRL + dimmed lights gone - FORSCAN DRL_
Ford Ranger Auto DRL + dimmed lights gone - FORSCAN Front
CoryB
Cory
Virginia
If you're willing to lose any other Forscan changes you made, you can find the original As Built file from Ford and restore it back to the way it came from the factory.
Ford As Built files
w_zsolti
Zsolt
Hungary
Ranger Wildtrak X
Contractor
Ford As Built files
Thank you! It worked!
Is there any workaround, to twist the full AB file to modules? Or a desktop editor for it?
CoryB
Cory
Virginia
Glad that worked! I don’t know of an editor to split the .ab file into the different modules. There might be one, but I don’t know of it.
I just make sure to save each module before I modify it. I keep a spreadsheet that shows the module, exact name of the setting I’m changing and the original and changed values. It’s saved me a couple of times when things didn't work as planned. Plus, I can always drop back one revision if I mess something up.
craigc
Craig
Allen, TX
I have a script I wrote to convert both ab and abt files to csv. It runs on a Linux shell. If you want to pm me your file I can run it or if you are good with Linux I can send you the script.
