Auto Fold Mirrors
Tagtexas
Tracy
I switched my auto fold mirrors “on” under settings. Doesn’t work. Anyone else have this issue? Maybe solved in a software update?
engus13
Clemmons, NC
2024 Ford Ranger Lariat Fx4
I have found I need to hold my finger on the handle for a little longer to fold the mirrors. A short press seems to just lock the doors and holding for 1/2 a second longer gets the mirrors to fold too.
superakcraig
Allen
Louisville, Ky
Locking with the fob seems to work good too.
Fawnbuster
Indiana
Mine work on my RR but I want to buy an auto fold module like I had in my 2019, I could lock the doors from inside with the doors closed and then unlock the doors and they would stay folded (helps alot in a cramped garage) same for locking via handle or the fob, lock, they fold and then unlock via fob or touch handle. The wont unfold at all until you either push the start button for accessories or start the truck. That module also had a roll windows partially or all the way down feature with the mirror fold but I rarely used that, I just got tired of the oem fold setup. I will see if I can locate a link for a new module and post it.
fordtrks4ever
Perkiomenville, Pa
As stated above
Works all the time when locking
Tailwagger
Ron
MA USA
Auto fold only works when you lock the truck. When I lock with the finger press on handle they fold every time for me.
You can fold the mirrors at anytime using the switch on the door as long as auto fold is enabled. I found this out the hard way driving down the road when I tried to adjust my mirror, hit the wrong button and the mirrors folded in on me. Presumably a feature for tight trails when off-roading.
Pg. 109 in the 2025 manual:
Ford Ranger Auto Fold Mirrors RRManualMirror
Looking at the last line there, might have been possible that the OP pressed the button which overrode the auto fold. Perhaps pressing it will right everything.
