Bed/Box Step
KrillOill
KrillOill
2025 RR
Make sure they work with the RR. My understanding is the reason Ford doesn't offer that option on the RR is the dual exhaust system gets in the way or maybe gets too hot. If you get them please post pictures installed. Where in CO are you? I'm also in CO with a RR. I've only seen two or three on the road since I got mine.
Yeah...I was worried about that. I'm in the Colorado Springs area.
jrRaptor
Maize, KS
Also the fender flare interferes - it is different than the non-Raptor's. So the 2 obstacles to overcome for a bed side step are the exhaust and plastic fender flare.
Moonlit
Pittsburgh PA
2025 Ranger Lariat (Marsh Gray, Rear Locker and BAP)
Moonlit
Pittsburgh PA
ok, got them installed. (2025 Lariat)
Ordered from Ebay - Took about 5 business days to show up at my house. They had said mid July to late August for delivery, so I was floored when tracking came back that it was going to be here in a few days.
Install is not as straight forward as you would think. The wheel well trim needs to come off to get to the black trim screw so that it can be removed. Snap clips on the part to remove are tougher on the exhaust exit side
Also had to drop the bumper down to get the old plastic parts out and new ones in.
Overall the construction of them is good and fitment is good as well.
Yell if you have questions on the install.
KrillOill
KrillOill
2025 RR
Can you measure the depth of the step from underneath of each side so those of us with Raptors can have an idea if they will fit on our trucks?
Moonlit
Pittsburgh PA
From the side in?
Fawnbuster
Indiana
On behalf of those of us with Tee Rex arms, I have often wondered why Ford never made the running boards/steps longer rewards so you could reach into the front of the bed easier.
They will fit on Raptor but only one side as the exhaust is in the way. Can't remember which side(think passenger side).
Fawnbuster
Indiana
Do the steps require any cutting of bedside or bumper?
Not on the non Raptor. Not 100% sure on Raptor if the bumper is different it might need a bit of trimming.
