MidnightSpecial
2025 Raptor Ranger
I see a lot of questions floating around about fitting big tires and if trimming is involved. From my own personal setup, the answer is yes. I probably could have gotten away with it if I am staying on road. However, I am going to mob this thing over the summer so I want to make sure I have the clearance.
Lets go over my setup:
- 2.25" perch collar from RPG Offroad
- 315/70r17 Wildpeak AT4w
- 17x8.5 +25mm RRW wheels
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 1744164597054-2l
This setup rubs at full lock on the inner tabs of the wheel wells. Therefore, time to chop.
Here is a picture of the passenger side fender tab. I have marked the line I chose to cut to keep it as clean looking as possible. The tab holding it down doesn't seem to be very structural. If you remove the tab the fender flair still feels very stable. However, there is a torx screw underneath you need to keep attached to keep the fender flair from wiggling around. I'll go over that next.
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 1744163866399-4c
Here is the underside of that fender flair tab we want to cut. As you can see there is a torx screw holding it down. Be sure to keep that screw attached when you cut. If you remove the screw, the fender flair will wiggle around freely. I have marked where we want to cut.
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 1744164107239-po
I chose to cut this away with a rotary tool but you could probably find other ways to get this done. Once you go through the plastic there will be some very thin soft metal that is easy to cut through. Here is what it looks like.
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 1744164230363-7q
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 1744164293599-i4
Here is the end result. Still need to clean this one up to make its more flush and ensure there are no sharp edges.
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 1744164361463-oj
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 1744164389716-dr
Here is an image of the driver side at full lock. Clears pretty well.
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 1744164458875-jq
I drove around on it and backed in the driveway where I have been rubbing since I put on the bigger wheels. I think this will solve the issue going forward. I'll be offroading soon so we will see if it helps while crawling!
GLT
2024 Ford Ranger Raptor; 2022 Ford F-150 Raptor 37
Thanks very much for posting this. Extremely helpful; this is exactly what I'll be doing.
BigMeatsBronco
Allan
Oregon
self
We did the same thing with our Ranger Raptor but instead of using a perch collar, we opted for Leveling spacers instead. 1.5" front and 1" rear. I prefer these because the ride height on the shock absorber is in the same place which also can affect the computerized shocks. Additionally the spring rate is not increased, and the struts still have the full range of motion. This does increase the down travel or droop slightly, and also allows for slightly less compression travel. So it moves the struts range of travel top and bottom limits downward by 1.5 in. In contrast the RPG spring collars just change the ride height by moving the position the Spring Rides on, and the overall shock high and low points remain the same. So at whatever ride height you're at you now have more compression available and less droop available compared to putting a spacer on top of the strut.
We also trimmed the same areas.
Tires are 35x12.50x17 Nitto Mud Grapplers
Wheels are Bronco Sasquatch
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 20250418_093742
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 20250418_093748
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 20250418_093754
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 20250418_093806
Danielr12
Daniel
ranger raptor
Mechanic
I did exactly this when I got mine and haven’t had any rubbing whatsoever after offroading a few times. A good option however is instead of cutting the metal tab behind the molding I actually just bent it back and It hides that white retainer thats now exposed.
Mystic
Rusty
SoCal
'24 RR, '25 Explorer ST
Estimator
Is the bronco wheel offset +30? Somewhat uncertain about how much poke I'm gonna get, and truck is going into the shop tomorrow.
Doing RPG adjustable collars all around (2.25"), 35x12.5 Toyo AT3 on Method 703s (+35)
Will post pics as soon as I get it back, natch
Reactions: GLT
BigMeatsBronco
Allan
Oregon
self
yes +30
Bondodave
2024 ranger raptor
Collision industry
I lifted mine with the leveling kit on top of the strut a year ago. 315/70/17 jumped it in the dunes been through almost every terrain possible zero rubbing stock wheels
Ford Ranger Big Tire Surgery Tutorial: Trimming / Cutting to Fit Large Tires 20250426_171751
MidnightSpecial
MidnightSpecial
2025 Raptor Ranger
That's awesome! Maybe my offset was causing the issue. The AT4W's are pretty wide compared to other 35's out there. I definitely had to trim
Bondodave
2024 ranger raptor
Collision industry
I'm putting 37x12.50s on this week. Stock wheels and offset. I will let you know if I had to change anything. I want more tire. I really do not think I will have to cut or trim anything. The offset makes a huge difference. That's why I haven't bought any other rims
MidnightSpecial
MidnightSpecial
2025 Raptor Ranger
Makes sense. The only concern you would have with the stock wheels is the tire hitting the upper control arm. If it clears that then you are golden.
Bondodave
2024 ranger raptor
Collision industry
It will not hit. The 315s are 12.5 wide already and they clear. Maybe a 1/4 inch but there's no flew at the top of the tire even when aired down. If anything I might have to remove the crash bars. It looks like it will be fine though. Just need a little more boost lol. I will bring it in to find that soon too. The FPT works great but I know there's more to be had with the AFR so fat at WOT. Can't wait for the next adventure
TacticalRRT
Shane
Indiana
2025 Ford Raptor Ranger
RRT
What leveling spacers did you use? Do you have a link?
