Cam phaser failure acknowledged
buddyleex
what are the risks of continuing to use/drive a truck with a cam phaser issue?
danmoochie
dan
florida
retired Sales manager
Mixed opinions. If not that bad and only at cold start they state minimal if any. If noise all the time I don't care what anyone says its doing damage. If mine comes back I'm getting it taken care of for sure while on warranty.
danmoochie
dan
florida
Ok I gave up. Traded it back in. Could not sit an wait for total cam phaser melt down. Still not sure how Ford lets this known issue occur. But I'm out.
AMGRAPTOR
FL
2024 Raptor Ranger
Do have a video of the noise you heard from a cold start?
danmoochie
dan
florida
danmoochie
dan
florida
WarFries
Does anyone know what the "stuck internal component" is for SSM 52772?
Is it just stuck until the oil pressure builds, or is it stuck all of the time and the oil pressure / lubrication is just masking it?
Bmadda
6gBronco, 4gBronco
Mechanic
It's really not too important, cause the phasers are serviced as an assembly, but what is going on is they leak down when the engine is off. There must be some type of check valve/ball to hold oil in the unit when the motor is not running. I would assume this is what they are referring to. they could also leak externally, and you would never know cause they are inside the timing cover, and that oil will just return to the pan. Once the oil pump is pumping and the are full again it's a non issue. When you install new ones they make that noise the 1st time you start it...should be quiet after that. This problem is not unique to Ford...honda is having alot of these too...and a few other makes
Deleted member 9086
A way to circumvent the lack of oil pressure at startup is to;
1. Hold the brake and push the accelerator to the floor, then push the start button.
2. Hold the starter button for about 3 seconds and the oil pressure will build exponentially.
3. Take your foot off the accelerator and it will start with full oil pressure to the top end.
Another way is to install this; thanks Chad @Mad_Motorhead
https://www.baxterperformanceusa.com/shop-by-make/ford-1.html ???
danmoochie
dan
florida
Yup. Your hole life on every start up and cross your fingers
Rangerjimm
2025 Ranger Lariat 2.3
I would consider it important since they have to take the engine out of a brand new $50k+ truck to change them.
LSU-B-Rad
Baton Rouge
My Cam Phasers are being changed now, but talking to the mechanic they are being replaced with the same phaser! So no update just the same piece of crap.
